David Hall 9 Posted July 5, 2016 Share Posted July 5, 2016 I am using some of the other features of the transmitter more as I progress with my flying. On one new model, I had to add lots of elevator trim, nearly to the limit. I was surprised to find that when I switched to a lower rate the trim changed dramatically. This can be seen on the display, when enough trim is set to appear on the bar, switching to a higher or lower rate changes the trim. Whatever trim is set, is affected by any rates change made. If the trim is at zero, no change is seen, but anything else causes movement. Not really what I would want in this feature. Is there something I might have missed? Quote Link to comment Share on other sites More sharing options...
MattyB Posted July 5, 2016 Share Posted July 5, 2016 Unfortunately it seems to be an acknowledged issue with this set... Quote Link to comment Share on other sites More sharing options...
David Hall 9 Posted July 5, 2016 Author Share Posted July 5, 2016 Ah, I'm not seeing things then.....I did search, but turned up nothing. Thanks for the link, I can stop trying to fix it now. Quote Link to comment Share on other sites More sharing options...
Max Z Posted July 5, 2016 Share Posted July 5, 2016 Posted by David Hall 9 on 05/07/2016 17:50:03: Thanks for the link, I can stop trying to fix it now. Why don't you fix it in the way it is described in that link, i.e. replace your trim settings with sub trim values? Quote Link to comment Share on other sites More sharing options...
David Hall 9 Posted July 6, 2016 Author Share Posted July 6, 2016 That's what I have done, of course after trying to get them nearer by adjusting the links. Thanks! Quote Link to comment Share on other sites More sharing options...
