john stones 1 - Moderator Posted September 26, 2016 Share Posted September 26, 2016 Won one of these in a raffle, anyone got/had one, any comments ? John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 29, 2016 Author Share Posted September 29, 2016 At the hinging stage on this, what's best glue for the foam to those furry mylar type hinges, precut slots are a touch loose so i'm doubting thin foam safe C.A John Quote Link to comment Share on other sites More sharing options...
Attilio Rausse Posted September 29, 2016 Share Posted September 29, 2016 I used kavan furry hinges and foam safe cyano, glued hinges into control surface first then (when dry) into body, do all my hinges in that order, I know that this is frowned upon but I have never had a failure (yet). On my maiden flight - when landing I ran out of elevator (low rates) and took my undercarriage off, don't know what to advise as mine was only lightly glued in so repair was quite easy, I have read that it needs glueing in with lots of epoxy trouble is then if you have a hard landing it will be hard to fix. looking forward to my next flight as i am using this plane as a test bed for the taranis S6R. Til Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 30, 2016 Author Share Posted September 30, 2016 Pre glued into the control surfaces Attillio but that's how i would have done it anyway, undercarriage is an odd method i agree, difficult to repair if you have a mishap. John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 30, 2016 Author Share Posted September 30, 2016 Few pictures of it, it's built fairly well but feels very delicate in my clumsy hands,power to weight should be good though. Cowl just hooks onto fuzz with those tabs you can see Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 30, 2016 Author Share Posted September 30, 2016 Quote Link to comment Share on other sites More sharing options...
john kennedy 4 Posted April 3, 2017 Share Posted April 3, 2017 Hi John, I've just acquired one of these in a swap deal. Can you tell me what servos,esc,battery and motor you used please. I agree it does feel very flimsy. How did yours fly? Is it still in one piece? I'm hoping to 'tame' it down a bit until I get used to it,then up the throws gradually. Thanks, John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 3, 2017 Author Share Posted April 3, 2017 It flies very well John, i'll look up what set up i used a bit later and get back to you. John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 3, 2017 Author Share Posted April 3, 2017 Here's Hobby Kings recommendations, the lipo mah is nonsense, i used 3300mah ones and only got 5minutes. I used stuff i had already John, hitec 225 servo's, too big i had to enlarge the holes, loads of servos that'll fit on H.K measure the holes and find some minis your happy with, Metal geared ones. Esc Plush60 amp in mine and motor is NTM35/48 900kv ...815 watts. lipo 4cell 3300mah. It flys very smooth, no bad manners and not twitchy if you reduce the rates, mine flap like barn doors on full rate but it's still nice to fly, landing/take offs very straightforward, aerobatics very crisp, 3D yep if you're good enough, i'm rubbish at it If i was buying, i would go with an SK3 from the 42 range at H.K and 5 cell lipo 4000-4500 mah. Nice model you'll enjoy it. John Quote Link to comment Share on other sites More sharing options...
john kennedy 4 Posted April 3, 2017 Share Posted April 3, 2017 Thanks for that.Very helpful. Being a cheapskate I'll give the Corona DS239MG's a try. Thanks again, John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 3, 2017 Author Share Posted April 3, 2017 No problem, have fun Quote Link to comment Share on other sites More sharing options...
