Bruce Richards Posted July 16, 2008 Share Posted July 16, 2008 Well My prize arrived this morning. Was addressed to Number 18 rather than 19 so my neighbour brought it round. I have looked through the box and at the instructions and I have a lot of bits to buy to get it in the air.2 X EDF fans I am thinking of GWS EDF55s. Does anyone know what motor spindle diameter they need? 2 X Brushless inrunners to suit above. Looking at purple power but would prefer somthing a little cheaper fr Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted July 16, 2008 Share Posted July 16, 2008 Oops sorry Bruce glad it arrived ok. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 16, 2008 Share Posted July 16, 2008 The GWS do not have the best of reputations for efficiency Bruce - try maybe the vassa units if price is not a problem...or otherwise the microfan from wemotec. I think airpower do a 48mm size but not a 55mm - Scott will correct me Im sure if I am wrong. Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted July 16, 2008 Author Share Posted July 16, 2008 What about a pair of these item top of page for £10 each and would this be a good match?I am on a budget for this model as it was not on my to build list. But I have build it now I have won it.Thanks Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 16, 2008 Share Posted July 16, 2008 well cant comment directly as I have never used them, and ike to reserve criticsm or praise only for items that I have actually had experience of. I guess at £10 a pop, they are worth a go, but ensure youtake time to balance them as well as possible before use. I take it that you will also need the intake rings /lips for the tankbuster layout.One thing that bothers me a bit with the motors you linked to is the power / current consumption. These are VERY high Kv motors and will possibly be pulling close on 25A and with a twin setup, thats potentially 50A !!I think thats way too much for a small GWS foamy - go for a lower Kv and then your battery and ESC can be smaller and lighter. Just my .02P worthPS - I thought the kit came complete with fans and motors included ?? maybe this one didnt. Incidentally the purple power set is not thta badly priced TBH it includes an ESC with each motor remeber. Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted July 16, 2008 Author Share Posted July 16, 2008 Timbo,I think you are right about those motors I will keep on looking. I also thought the Kit came with fans and motors but not this one unfortunately. I think it will be the most expensive prize I have ever won...Has anyone else ever built one of these? Quote Link to comment Share on other sites More sharing options...
Nick Rigg Posted July 17, 2008 Share Posted July 17, 2008 I'd like to recommend Foamyjets who specialise in this kind of thing and have always provided me with terrific service... Quote Link to comment Share on other sites More sharing options...
Steve Smith Posted September 3, 2008 Share Posted September 3, 2008 Bruce I have a GWS A10, it came with fan units and motors, however GWS sell the A10 as just the body painted and unpainted too, sounds like you got that kit. Even though my kit came with the fan units and motors the motors were not brushless and there are a lot of reviews online about under power from can motors installed in this model. With this in mind I dumped the cans and went for brushless right away but kept the fan units. I have used Walkeran helecopter inrunners with a 60amp ESC on a 3cell 1500mah lipo and the performance is stunning. Loads of thrust and once up you can pull back on the power to save the lipo as she flies well at slow speed.I have just stripped out the 35mhz radio gear and gone over to 2.4gig so just waiting for a good weather day to fly.Steve Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted September 3, 2008 Author Share Posted September 3, 2008 Thanks for the info Steve. I have to say I have put mine in the "to do" pile it was just going to cost more than I was willing to spend right now. I have a Phase 3 F16 that I have not flown yet so that comes first. Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted May 14, 2009 Author Share Posted May 14, 2009 I have almost finished the A10 now. I have tried 2 different brushless motors and ended up with these and GWS 55mm fans. I also tried the 4800Kv variant of these motors but they were too fast and pulled too much current. I now have 300W on a 25oz air frame, should go OK. Edited By Bruce Richards on 14/05/2009 14:20:12 Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted May 25, 2009 Author Share Posted May 25, 2009 Maidened the A10 yesterday. First flight belly flop straight into the ground despite full up elevator. Both fan pods snapped off. Glued them back with some 5 Min epoxy. Second attempt with more elevator throw. It flew but used up all the up trim and had to hold in about half stick up to keep it in the air. Then on a slow low pass I ran out off up stick and it flopped into some long grass. Wing mounting pulled out tail snapped and elevator servo come adrift. Not sure if the servo was the cause or result of the crash. Tried again today after some changes. fixed up all the broken bits and set up trim with some up elevator when the Tx trim natural. Also moved the battery back 10-15mm. It flew a treat lots of power when needed and nice low slow passes. Could do with more movement on the ailerons but no trim changes needed to fly straight and level. David can you send me a nice pristine one so that I can move my gear over now I have a working set up and a scruffy model? Edited By Bruce Richards on 25/05/2009 16:28:49 Quote Link to comment Share on other sites More sharing options...
