Mark Kettle 1 Posted February 12, 2017 Share Posted February 12, 2017 Phil Cooke built this model from the Durable Aircraft Models EPP kit , this large Lockheed T-33 'Shooting Star' spans an impressive 72" and has an AUW of approx 5lb. The model is completely formed from white EPP with hardwood spars in wing and tail. It is finished with strapping tape, white Solarfilm and Trim. The tip tanks also from epp foam are a 'push fit' onto the wing and are designed to knock off if required on landing. Model uses 4 channel RC for elevator, aileron, rudder and nose release fitted for aerotow. The model uses the wing section SD3021. Wing section view / sample : http://airfoiltools.com/airfoil/details?airfoil=s3021-il Edited By Mark Kettle 1 on 12/02/2017 17:14:42 Edited By Mark Kettle 1 on 12/02/2017 17:15:44 Quote Link to comment Share on other sites More sharing options...
