AndyD Posted September 17, 2017 Share Posted September 17, 2017 ive got a new problem with my spitfire,the electric retracts when retracted in the air just keep cycling going up and down all the time.luckerly when switched to down position they stay down,im thinking ign inrtference of some kind as when tested on the ground alls well and good but that's with the engine not running,could there be another reason of some kind many thx,Andy. Quote Link to comment Share on other sites More sharing options...
Colin Hooper Posted September 17, 2017 Share Posted September 17, 2017 I have had similar problems with e-flite retracts in the past. It has happened with all sizes and in different models. As you say, they always stay down when you want them to but it reduces your confidence in them. I eventually replaced them all with other manufacturers products. I never discovered why they cycled so if anyone can throw any light I would also be interested. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 17, 2017 Share Posted September 17, 2017 **LINK** Download the PDF on connectors cause in a cycling problem Edited By Denis Watkins on 17/09/2017 17:40:08 Quote Link to comment Share on other sites More sharing options...
AndyD Posted September 17, 2017 Author Share Posted September 17, 2017 thx for that Denis had a read through so re checked the connections,and found one that was taped rather than having a proper connecter on it,it seemed to have pulled out slightly but wont no if its sorted until I fly it again. Quote Link to comment Share on other sites More sharing options...
