David Hall 9 Posted September 20, 2017 Share Posted September 20, 2017 After only a little use, the firewall of my 2m Phoenix is fractured around the mounting plate used for the motor. I think that it might be better to fix a new ply firewall to the inside of the fus using what's left of the moulded plastic one. It's advertised as being made of nylon. I tried a test glueing with UHU "All Plastics", but this had no effect on the nylon although it did stick to the plywood a little. The surface of the plastic was untouched by the glue. Can anyone suggest a glue that might be good for fixing the firewall to the fus? Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 20, 2017 Share Posted September 20, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bryan Anderson 1 Posted September 20, 2017 Share Posted September 20, 2017 See a post from McG in Belgium who answered this some while back. Take a look at **LINK** Quote Link to comment Share on other sites More sharing options...
David Hall 9 Posted September 20, 2017 Author Share Posted September 20, 2017 Posted by Bryan Anderson 1 on 20/09/2017 13:02:17: See a post from McG in Belgium who answered this some while back. Take a look at **LINK** Well found! thanks for the pointer. (not too cheap then) Dave Edited By David Hall 9 on 20/09/2017 13:14:33 Quote Link to comment Share on other sites More sharing options...
