fly boy3 Posted March 3, 2018 Share Posted March 3, 2018 Hi all, I need to remove a lot of pictures from my old PC before it dies lol. I am trying to down load them to a memory stick. Can I just click on the words " my pictures" or will I have to highlight each one and do the hard way. Thanks Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted March 3, 2018 Share Posted March 3, 2018 Highlight the folder you want to copy. Press <CTRL C> then go to the destination directory and press <CTRL V> Called copy and pasting, Commands are: CTRL C Copy CTRL V Paste CTRL X Cut. so you can use cut and paste/copy and paste. The commands can be done under the drop-down box, but is quicker and more positive. Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 3, 2018 Share Posted March 3, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted March 3, 2018 Share Posted March 3, 2018 I was using the simplest way, as sometimes the mouse control if you're not in control you can make a mistake. Quote Link to comment Share on other sites More sharing options...
Keith Lomax Posted March 4, 2018 Share Posted March 4, 2018 If you are using keystrokes, then CTRL A is select all. If you want all of the pictures together in a subfolder on the memory stick, take the whole folder using Paul's method, or just drag it between two windows of explorer (one for the PC and one for the memory stick. If you want to move them to the root of the memory stick (may be necessary if you want to display them on a smart TV, for example) then go into the pictures folder and select all then copy - using either mouse or keystrokes - then go to the memory stick folder and paste. Quote Link to comment Share on other sites More sharing options...
Richard B (DB Sport and Scale Ltd) Posted March 4, 2018 Share Posted March 4, 2018 If they're very important photos, I'd copy them to two places before your old PC goes or are deleted. Memory stick and new computer or two memory sticks, memory stick and DVD, etc, etc. One memory stick can go wandering or get damaged. Quote Link to comment Share on other sites More sharing options...
