Brian Matthews Posted September 7, 2008 Share Posted September 7, 2008 Hi, I have just bought a Multiplex Minimag along with some Zacki Elapor glue. The bottle says to read the instructions, what instructions? Has anyone used this stuff? I think that I read somewhere that a kicker is not needed for this glue. Any assistance will be appreciated.ThanksBrian Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 7, 2008 Share Posted September 7, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted September 7, 2008 Share Posted September 7, 2008 I am pretty sure that elapor is safe when used with regualar cyano rather than the foam safe stuff. I think use of kicker is optional. Quote Link to comment Share on other sites More sharing options...
Pete Rieden Posted September 7, 2008 Share Posted September 7, 2008 "Zacki" is cyano. For Elapor use ordinary (not "foam safe") medium cyano. Multiplex have a good tip in the instructions - spray activator on one surface and let it dry, then aply the cyano to the other side and bring the two together to make the joint. This is a good way of ensuring that large-area cyano joints actually cure all the way through! letting the activator dry before making the joint slows the cure slightly, so it's not a sudden grab.PDR Quote Link to comment Share on other sites More sharing options...
Brian Matthews Posted September 8, 2008 Author Share Posted September 8, 2008 Thanks, by activator do you mean kicker? I have never used any of this stuff before. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted September 8, 2008 Share Posted September 8, 2008 Yup, same stuff Brian. Quote Link to comment Share on other sites More sharing options...
Brian Matthews Posted September 8, 2008 Author Share Posted September 8, 2008 Thanks for that. Quote Link to comment Share on other sites More sharing options...
