Zacki Elapor glue
Brian Matthews
"Zacki" is cyano. For Elapor use ordinary (not "foam safe") medium cyano. Multiplex have a good tip in the instructions - spray activator on one surface and let it dry, then aply the cyano to the other side and bring the two together to make the joint. This is a good way of ensuring that large-area cyano joints actually cure all the way through! letting the activator dry before making the joint slows the cure slightly, so it's not a sudden grab.
PDR
