Terence Lynock Posted September 18, 2008 Share Posted September 18, 2008 I built a nice little glider for slope from a plan for 'Flying Fox' an old plan I had in my colleciton for a while, extended the wing a little by adding a centre section rather than have the dihedral start on the centre line. Incidence is about 3'.It is a high wing 45'' span with fairly slender fuse and wing loading about 7.5 oz with COG at 30% cord, balance is nice in both horizontal axis but when I tried to see how it would glide today it showed much reluctance dropping the left wing and nosing in as soon as released.How much wind do you need for a bird to stay up on the glide? it was very calm today with just the feintest of breezes from the south but I would have expected the bird to at least glide for a few yards just to show me if it was going to turn into a lawn dart or not which it did try to.Perhaps it just needed more forward speed as chucking a 45'' span fast enough for it to obtain lift looks to be harder than I thought it would be,regards. Quote Link to comment Share on other sites More sharing options...
John Bunting Posted September 19, 2008 Share Posted September 19, 2008 Hi Terence,With that span and loading, I guess your model weighs a bit under a pound and has a wing area of about two square feet, and should have a fairly moderate flying speed, not difficult to hand-launch, even in calm conditions. The C of G position sounds about right, so if it persistently heads for the ground , with no tendency to stall, maybe it needs a bit more up elevator. I assume it's just two-channel, rudder and elevator, with no ailerons, and you say the balance is OK in both axes, so if it always drops the left wing, could there be a wing warp somewhere? What was the original wingspan and area, before adding the centre-section? The larger wing area means that the tailplane is now a smaller percentage of the wing area, which may affect the longitudinal stability. Can you confirm the weight, and give us the wing and tailplane areas?John. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted September 19, 2008 Share Posted September 19, 2008 Yes Terence is should glide quite well. From say 6ft you should get at least 40ft if you launch it at flying speed with no wind. Your description certainly sounds like it did not have flying speed, remember in still air it is likely to need quite a firm throw. Try holding it level & running with it, you should be able to feel it want to lift from your hand when you are going fast enough. As a rough guide to stay up on a reasonable slope you will need a wind speed of about half its normal flying speed but it can get more complicated than that! Any chance of a picture? Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted September 19, 2008 Author Share Posted September 19, 2008 Well, not sure if I have calculated the wing area correctly the more I think on it, the main panel is 30'' x 5'' = 150 sq inches.The combined outer panels = 8'' x 9'' = 72 sq inches so total area is 222 sq inches.weight is 360g all up with battery etc = 360 / 222 = 1.62g sq in = 1.62 x 144 = 233.2 /28.4 = 8.21 oz sq ft which is slightly higher than I first thought.Area of the complete stab and elevator is 23 sq in. Area of the Fin and rudder is 14 sq in with rudder = about 50% of the total area.Original span was 40'', with addition of centre section and semi-circular rounded tips now 45'', outer panels have leading edge sweep from 5'' to 3'' over a 9'' length. Aerofoil section is very simular to a Clark Y.This is about all I can tell you folks, by my calculations it should fly but is making hard work of it, regards. Terry Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted September 19, 2008 Author Share Posted September 19, 2008 Thoughts on thoughts, may try it with my short Bungee if everything checks out, the field I am using is long grass gone to seed now so soft landings are no problem even at speed, regards, Terry Quote Link to comment Share on other sites More sharing options...
Alistair Taylor Posted September 19, 2008 Share Posted September 19, 2008 Hi Terry I think I remember this plan - and if it's the one I'm thinking of, it had quite a slender winf profile, so it should penetrate well, but it will need a bungee or reasonably powerful chuck to get it into the air - was it pictured in pink solarfilm in the build article?Alistairt Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted September 19, 2008 Author Share Posted September 19, 2008 Thats the one Alistair, quite a nice slender fuse and squarish stab abd fin, I have sprayed my fuselage with a Ford metalic paint called Ameranth Pearl which is a pearlised Purple metalic and covered the wing in a deepish pink, the wingtips are a square patterned holographic purple on the underside and very reflective like a faceted purple mirror.Presently looking at making a smaller and lighter launching ramp than the one I have that I can take apart and pack into a bag with my bungee, do you think 15 degree angle is enough for the job or should I make it variable?, regards, Terry Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 19, 2008 Share Posted September 19, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
John Bunting Posted September 19, 2008 Share Posted September 19, 2008 Hi Terence,The tailplane area of 23 sq ins is just over 10% of the wing, which might be a bit too small; but of course the moment arm, the distance between wing and tail, also affects the stability. As Simon and Alistair said, it might need a good heave to get it leaving your hand at flying speed. Do you have access to a good slope-soaring site? If so, with a good breeze up the slope, I don't see how it can fail to fly, even if only for a short hop. Once it's in the air, you should find how controllable it is, and what needs changing, if anything. Keep us informed!John. Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted September 20, 2008 Author Share Posted September 20, 2008 Will do John, the problem with this area is most of the decent sites have been built on or filled with bloody trees so finding one where you have a half decent chance of testing a new airframe without major obstructions is becoming harder.I can enlarge the stab by slicing off the leading edge and grafting on an extra piece to give it more cord and span and likewise with the fin if need be, it isnt major surgery so will keep it as an option for the future, regards, Terry Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted September 20, 2008 Share Posted September 20, 2008 Eric - not really pinched, limiting wind speed to 1/2 flying speed is sound advice even on full size gliders, however you did say it first, although it was in another thread! Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 20, 2008 Share Posted September 20, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
