Nitro Flyer Posted October 18, 2019 Share Posted October 18, 2019 Hello people,i am building a WOT 4 XL and recently purchased the Etronix dual power switch for RX and ignition,im now not sure if i should use it or not,as where the wires are soldered to the switch pins look very flimsey,and have no heat shrink covering the soldered joints,im thinking vibration could cause the wires to break off,any of you ever use thease switches or recomend them,many thanks in advance.. Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted October 18, 2019 Share Posted October 18, 2019 Not used them exact ones but used similar AGMhobbies ones which look very similar. Not had any problems but if you have doubts about wires vibrating loose, try using a hot glue gun and squirting a blob of glue onto the wires / switch to hold everything in place. I tend to do this in similar situations. Quote Link to comment Share on other sites More sharing options...
Nitro Flyer Posted October 19, 2019 Author Share Posted October 19, 2019 Hi Gary Manuel, thanks very much for your reply and link Quote Link to comment Share on other sites More sharing options...
