Exaur Posted September 1, 2020 Share Posted September 1, 2020 About to start covering a Cambria Elan 100 inch glider and am considering using polyester tissue as a change from see through film. The airframe is strong enough for me uncovered and I am not sure whether to use the Standard or Heavyweight version of polyester tissue that seems to be available - I'm assuming light may be a bit fragile as it seeme to be used for very small models. Main use of glider will be slope or bungee (and probably a future ePower Pod) with reasonably smooth landing areas. Would this material be suitable? Many thanks for any advice. Quote Link to comment Share on other sites More sharing options...
Martin Hodgson Posted September 3, 2020 Share Posted September 3, 2020 Polyester tissue is quite tough. You should be fine with the standard- it is the one I would choose. The elan is a light(ish) thermal soarer so keeping weight low is important. Quote Link to comment Share on other sites More sharing options...
