Skydiver build blog
The second chute a and the final one were test dropped off a 60 size stick. The pilot had his hands full with 750 grammes added well behind the planes CG....and then suddenly be removed again...
These tests revealed that the second chutes material was too heavy. The third chutes material was then lighter and works perfectly.
My little camera recorded the drops. Not to mention the roller coaster ride to altitude..
The front cover is balsa sheet. I was concerned about the strength thereof so I glassed the inside. The 'bump' on the cover is what would be the real skydivers reserve parachute. The plans call for this to be hollowed out so that the batt. pack can be fitted inside but I found this space to be far too small. I ended up epoxying some lead into the hollow.
