OS48 Surpass parts
Brendan Fogarty
Are you sure there should be two, on some engines the gudgeon pin can only be put in from one side of the piston, on the other side of the piston the hole has a step to prevent the pin going all the way through.
If indeed you need two, and you have one of them do you know anyone with a lathe who can copy the one you have, I thing they are made from nylon but possibly something like PTFE.
