Louis Benjamin Posted October 16, 2008 Share Posted October 16, 2008 hi ,can another FUTABA F617FS receiver be linked to my tranny. if so....how.thanks Quote Link to comment Share on other sites More sharing options...
Michael Hickman Posted October 16, 2008 Share Posted October 16, 2008 Hi Louis, I am only a "Trainee" but so far as I am aware, please correct if I am wrong, you can bind to several different RX from one TX. However each RX can only be bound to one TX. Mike Quote Link to comment Share on other sites More sharing options...
Louis Benjamin Posted October 16, 2008 Author Share Posted October 16, 2008 hello michael, thanks for info. do you know how this is done by any chance? Quote Link to comment Share on other sites More sharing options...
Michael Hickman Posted October 16, 2008 Share Posted October 16, 2008 Hi LouisFollowing is taken from page 9 of my manual.Link ProcedureEach transmitter has an individually assigned, unique ID code. In order to start operation, the receiver must be linked with the ID code of the transmitter with which it is being paired. Once the link is made, the ID code is stored in the receiver and no further linking is necessary unless the receiver is to be used with another transmitter. (For T/R set, the link is already done at factory. When you purchased another R606FS, this procedure is necessary; otherwise the receiver will not work.Place the transmitter and the receiver close to each other within one (1) meterTurn on the transmitter.Check the LED that is placed on the back side of the transmitter to see if the RF signal is active. When the green LED is ON solid, the RF signal is being sent.Turn on the receiver.Press down the "ID SET" switch for more than one second, and release the switch. The receiver starts the linking operation.When the linking is complete, the LED in the receiver will change to solid green. Please confirm that the servos will now operate by your transmitter. Please refer to the table below for the LED status of the receiver's condition. No signal reception Red : OnReceiving signals Green: OnReceiving signals, but ID is unmatched. Green: BlinkUnrecoverable failure (EEPROM, etc.) Red and Green turn on alternately I hope this helps, I would think that the procedure for F617FS is very similar. Mike Quote Link to comment Share on other sites More sharing options...
Louis Benjamin Posted October 16, 2008 Author Share Posted October 16, 2008 thanks for that mike, i`ll try it as soon as i get it installedlouis Quote Link to comment Share on other sites More sharing options...
