John Cooper 1 Posted February 4, 2021 Share Posted February 4, 2021 When using "thin" cyno (Rocket Hot) should you remove the read droppers every time or can you leave it on? Quote Link to comment Share on other sites More sharing options...
Toni Reynaud Posted February 4, 2021 Share Posted February 4, 2021 I leave it on, especially if I'm likely to be glueing more in the near future. However, after use and before putting the bottle down I point it in an upward direction away from me and the bench and give it a quick squeeze. This clears any liquid glue left in the dropper. Failing to do this can lead to a clogged up dropper, and you will either have to ream it out with a pin (if you have good eyesight) or cut a few mm off the end to get it to flow free again. Quote Link to comment Share on other sites More sharing options...
MattyB Posted February 4, 2021 Share Posted February 4, 2021 ...+1 to all that, and store it upright in the fridge for longer life. Quote Link to comment Share on other sites More sharing options...
