Bridon Posted March 27, 2021 Author Share Posted March 27, 2021 1 hour ago, PatMc said: For batteries you could try Component Shop they have a greater range of batteries. I'd advise going for the Eneloops at least for Rx, they're more expensive but have lower internal resistance, meaning that the voltage doesn't sag as much as other types. You can get higher capacity batteries but they can cause problems when subjected to higher loads. E.g. when a glider is on landing approach using crow brake system. PS Eneloops also discharge at a very low rate when not in use, Vapex Instants are also low discharge but in my experience don't hold their voltage as well under load. IMO Vapex Instants are more economical & fine for a Tx but Eneloops are best choice for Rx. Good advice. ? Quote Link to comment Share on other sites More sharing options...
J D 8 Posted March 27, 2021 Share Posted March 27, 2021 Plus 1 for Components Shop.? Quote Link to comment Share on other sites More sharing options...
