X9D Plus updated to v2 firmware but can't change from mode 1
Allan Bennett
I've just updated my X9D Plus mode 3 trannie to V2 firmware following advice in this thread, but the electronics thinks it's in mode 1 and I can't change it to mode 3.
In the Radio Setup screen I've set Default channel order to AETR and the Mode to 3, but it still thinks that the right stick up/down is the throttle, for it gives the "Throttle warning" message when I power up, and the wrong channels respond in the Channel Monitor screen.  I suppose I could untick the 'Throttle warning' box in the OTX Companion setup screen, and then simply figure out which channel responds to which at the receiver, but that'll mess up other programming such as the throttle-cut function.
