Lee Morgan Posted November 10, 2008 Share Posted November 10, 2008 Ok so I got the model sir , What next ? I got a toy for me birthdayTimbo you dont want this buzzing the lip past your bonce mate Just incase you dont know , Its a Tragi 702 PNS F3F sloperCool as Lee Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 10, 2008 Share Posted November 10, 2008 Very nice..... gonna bring it over for a play some day ? Quote Link to comment Share on other sites More sharing options...
iawnski Posted November 10, 2008 Share Posted November 10, 2008 better wait for me lee gotta see that go ,combat anyone lol Quote Link to comment Share on other sites More sharing options...
Lee Morgan Posted November 10, 2008 Author Share Posted November 10, 2008 I will bring it for a play sometime soon chaps, Gota find the money to get servo's for it yet lolIwanski if you can catch it your welcome to try and take it out lmao ( No chance )Lee Quote Link to comment Share on other sites More sharing options...
Slopetrashuk Posted November 10, 2008 Share Posted November 10, 2008 Bet you don't know what PNS stands for though........Andy(Who does...) Quote Link to comment Share on other sites More sharing options...
Lee Morgan Posted November 10, 2008 Author Share Posted November 10, 2008 Goes something like this AndyThe PNS is rumoured to stand for Preben Norholm Special. Preben is widely regarded as the father of F3F and the special relates to the increased amount of glass fibre used during the model’s construction. I always do loads of research before I buy anything mate, I have just got the servo mounts for it cubits and found 4 hs85mg's for the wing , If anyone has a couple of hs225mg's floating around then I would be ready to fly Lee Quote Link to comment Share on other sites More sharing options...
Slopetrashuk Posted November 10, 2008 Share Posted November 10, 2008 Good man.This is Preben: Quote Link to comment Share on other sites More sharing options...
Les Littleton Posted November 10, 2008 Share Posted November 10, 2008 Wow what a posh hanger , leather sofa ! mines only got a lawnmower to sit on and lots of spiders .Nice wings to by the way. Quote Link to comment Share on other sites More sharing options...
Lee Morgan Posted November 10, 2008 Author Share Posted November 10, 2008 I need some servo arms for my HS85MG's Where do i get them from , Only need 4 of the same Lee Quote Link to comment Share on other sites More sharing options...
Slopetrashuk Posted November 10, 2008 Share Posted November 10, 2008 Lee - I use HS85's a lot but never with the standard servo arms supplied. I much prefer the beefier arms supplied with a standard size Hitec servo which fit. There is a specific type which I hoard for my 2m moulded stuff (where I use the 85's). What you need are a couple of packs of standard servo arms from amerang or Inwoods. You should get two of one type for the ailerons and two of a similar second size for the flaps.Andy Quote Link to comment Share on other sites More sharing options...
Tom Satinet Posted November 11, 2008 Share Posted November 11, 2008 yeah, I'm the same. I use the servo arms of hitec 311, 325s etc. They are beefier and the hole is the perfect size for a clevis pin. just don't ride the elevator to the bottom of the hill on this one mate! Don't fear it, they have an amazing amout of grip. Quote Link to comment Share on other sites More sharing options...
Tom Satinet Posted November 11, 2008 Share Posted November 11, 2008 I notice the aerial is sticking out of the back of the fuse? you don't need to do that, there should be a little tube in the fuse for the aerial to slide down. The fuse has carbon reinforcement, but not enough to warrant putting the aerial on the outside. certainly not with a mpx IPD, which i seem to remember you said you are using. although the aerial must be extended because that wire is oranage on that rx........give me a shout if you want to talk settings. Quote Link to comment Share on other sites More sharing options...
Lee Morgan Posted November 11, 2008 Author Share Posted November 11, 2008 Hi TomI will disreguard the comment about riding the elevator Cos I have done further investigations into MPX transmitters and found they have a few common prob's, It was glitching sir !!!How can you extend the aerial ? will that not have other implications as far as the freq? and stuff ( not very clever with this sort of thing )Lee Quote Link to comment Share on other sites More sharing options...
Tom Satinet Posted November 11, 2008 Share Posted November 11, 2008 often people extend the aerial to make it dangle out the back of the fuse on a carbon fuselage plane. You just solder a bit of wire on the end! people also sometimes send two bits of metal up the v-tail and solder that to the aerial wire. or a single bit of piano wire sticking out the back., and so on.The point is that the aerial should be fine inside the body of the tragi, there should be an orange tube below one of the pushrods, empty, for you to slide the aerial up. there appears tp be an aerial sticking out the back of yours... anyway, it's not something to avoid as such, just not really needed on this plane.ref the frequency thing, i believe a 35mhz aerial would have to be several metres long to be the "true" correct size. the rxs cope fine with an extended one. Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 11, 2008 Share Posted November 11, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Lee Morgan Posted November 16, 2008 Author Share Posted November 16, 2008 Well thanks to alot of help ( he did all the work ) from a mate the Tragi is ready to fly,All throws need setting then just a little of the right wind and we'll be off Cheers alan Best regardsLee Quote Link to comment Share on other sites More sharing options...
iawnski Posted November 17, 2008 Share Posted November 17, 2008 keep us informed mate Quote Link to comment Share on other sites More sharing options...
Lee Morgan Posted November 21, 2008 Author Share Posted November 21, 2008 Hi allWell the day arrived , But before I go into that a little warning ...................... FUTABA servo arms may seem to fit HI-TEC servo's but they dont !!!!! Please be aware of this I found out last night after having a few suspitions. I bought the arm's from a shop where the owner advised me that they do fit. THEY DON'T !! Anyway fortunatly it wasn't to much work to sort it out So after re-sorting the centre's we went to a secret location to try the Tragi out . Weather man said it might rain, basically means it's going to rain , But we headed off to the slope, Got it all together after trying the air with a bedlam and My mini nyx, The lift was great but there was a few patches of sink just had to be a little carefull.Plan was I launch and Alan was to pilot the Tragi , Alan has a Tragi and knows how to .. She flew out straight and true, 1 click of down and she was all set, Fantastic what a little time spent setting up can do , so five min's into the flight and Alans that happy with it he starts doing cuban 8's and looping consecutivly % times I think, I had a little fly around , did some roll's and a few stall turns but my hands were shaking, alot of money out there Hmmmmm. any way it was great and the landings were super, here's some pics just to show off a little double click for a bigger pic Great modelCheers Lee Quote Link to comment Share on other sites More sharing options...
Alan Dunstan Posted November 21, 2008 Share Posted November 21, 2008 Wasn't bad was it Lee. Very nice aeroplane and a super colour scheme. Alan Quote Link to comment Share on other sites More sharing options...
Lee Morgan Posted November 21, 2008 Author Share Posted November 21, 2008 Here's more pic's just to make you a little more jealousBest RegardsLee Quote Link to comment Share on other sites More sharing options...
Slopetrashuk Posted November 22, 2008 Share Posted November 22, 2008 Where is that hill Lee? Quote Link to comment Share on other sites More sharing options...
Lee Morgan Posted November 22, 2008 Author Share Posted November 22, 2008 Its a Secret Quote Link to comment Share on other sites More sharing options...
Slopetrashuk Posted November 22, 2008 Share Posted November 22, 2008 Looks crap anyway....... Quote Link to comment Share on other sites More sharing options...
Lee Morgan Posted November 22, 2008 Author Share Posted November 22, 2008 lol Good reply Lee Quote Link to comment Share on other sites More sharing options...
001 Posted November 22, 2008 Share Posted November 22, 2008 West of Norfolk! Quote Link to comment Share on other sites More sharing options...
