Esc programming - heli to fixed wing.
I’m trying to use a spare Align esc (RCE-BL100A)  in a fixed wing model. I got the esc (new) as part of a combo but didn’t use it in the helicopter, so it’s been sat around for a little while.
The snag is it’s set up in helicopter mode - is there a way I can turn it into a fixed wing esc? At present it’s got the soft start and governor features enabled (amongst others I believe) which are not needed / desirable in its new task. I think I could do this with the Align programming gadget but wondered if there’s a work-around? I’ve asked at my local club but as a electric heli-guider I’m a minority!
thanks all,
ian.
Do you mean a programming card? I had this issue with a YEP ESC that came set up for helicopter which I did not realise until my fixed wing model was in the air. The only way to change to fixed wing was with a programming card.
Found the manual.
G20525 RCE-BL 100A.pdf
Looks easy enough, as you say gadget. ?
Steve
