Delta Whiskey Posted November 18, 2008 Share Posted November 18, 2008 Hi All, need advice please! I just brought an already made Ultimate Biplane with an OS 52 engine, as my second aircraft after flying a trainer sucessfully for the last few months. (Been flying helis too for the last 6 months)...anyhow, I've managed to get the Tx somewhat working, except for one aileron, both servos work in the wings, as I've swapped their connections around, the one that works, is connected to channel 1 of the RS 70 Rx, which shows as throttle on the reciever itself, (the throttle control itself is working correctly - left stick), the plane came with two cables left hanging from the fuselage, for which I assumed were both for the ailerons, the 2nd cable connected to the aux 1 connector on the Rx, but it does not function as an aileron should, and as the other cable does, connected to channel 1 as described, do I need a y cable or it this something I need to configured on my Tx which is a T7CP? Quote Link to comment Share on other sites More sharing options...
simon barr Posted November 18, 2008 Share Posted November 18, 2008 Hello DW,The usual thing to do, using a 6/8 channel rx, is to connect the right wing servo to channel 1, and the left to channel 6. Then activate the flapperon mix in the tx which should now operate both ailerons. If they both go the same way, you will need to reverse the incorrect one in the tx. However, I don't recognise your radio gear, and if throttle is on channel one, (its usually channel 3), then you may just have to connect both ailerons with a Y lead to the correct aileron channelHope this helps,Simon. Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted November 18, 2008 Author Share Posted November 18, 2008 OK thanks Simon, I'll do some more investigation, I think the confusion of channel names on the Rx is because I've just realised it's a JR Rx not a futaba as I stated above, I'm told that JR and Futaba name them differently!The right and left wing servos are connected as you say to ch 1 and ch 6, (throttle & Aux1 according to the JR rx labelling), ch1 works fine, ch6 does nothing, I'll look up the flapperon mix on my Tx if I can find it! Thanks again. Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted November 18, 2008 Author Share Posted November 18, 2008 Help, where is the flapperon mixing on the T7CP ? Quote Link to comment Share on other sites More sharing options...
simon barr Posted November 18, 2008 Share Posted November 18, 2008 If you are mixing Futaba tx with JR rx, make sure your crystals are both Futaba, and range check the set-up to comfirm compatability. If it was me, I would use a Futaba rx.You will only have flapperon mix if the tx is a computer set. If it is not, you will have to Y lead the two servos together. Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted November 18, 2008 Author Share Posted November 18, 2008 The RX is a synth one, I just hit the scan button on it, and it seemed to tie in with my TX first go! So the RX does not have a crystal. I have to dig out the manual for the Tx. Quote Link to comment Share on other sites More sharing options...
simon barr Posted November 19, 2008 Share Posted November 19, 2008 Has it got a screen? If not, it will be non computer Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted November 19, 2008 Author Share Posted November 19, 2008 Hi Simon, it is a computer one, and has a screen, I found the flaperon setting, and once I reversed ch 6 the ailerons worked as they should, although, one only though has very little down movement compared to the other one, so I'm messing around with the trims a bit now! Thanks for your response. Quote Link to comment Share on other sites More sharing options...
simon barr Posted November 19, 2008 Share Posted November 19, 2008 It will probably be the end point adjustment that needs sorting...probably titled either EPA or ATV (Adjustable Travel Volume). Each channel has its own settings so check both 1 and 6. Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted November 20, 2008 Author Share Posted November 20, 2008 Yep, you are correct Simon, the end point on ch 6 was set wrong. Many Thanks, just gotta get the nerve to fly it now, engine fired up lovely, and sounded great! (OS 52 Surpass 4 Stroke) Quote Link to comment Share on other sites More sharing options...
simon barr Posted November 20, 2008 Share Posted November 20, 2008 Quote Link to comment Share on other sites More sharing options...
