Gull Wing Glider made from a Lidl or two
Hello again,
The templates are now available to download here if you wish to build this glider.
You will need some Balsa TE Or make some as I did from 6x40mm Balsa sanded to shape and length.
You will also need some thin steel wire for the push rods, Control horns, Foam safe glue, Hot Melt glue
Two 6g servos, A small 4ch Rx and a small battery I used a 18650 cell.
The all up weight for this one was 215g possible due to the stickers I added.
The balanced point is on the Leading Edge of the wing tips.
Enjoy, It is a fun model to fly and will not break the bank.
DownLoad Gull Wing Glider Templates
Steve.
