Joao Alves Posted January 29, 2007 Share Posted January 29, 2007 Hi.I'll build this warbird but I would like to now if it is possible to do it with combustion engines instead electric.Is this conversion possible?Regards,Joao Quote Link to comment Share on other sites More sharing options...
Joao Alves Posted January 31, 2007 Author Share Posted January 31, 2007 Hi again.Tony, can you help me on this question, please? (First posted)Thanks.Regards,Joao Quote Link to comment Share on other sites More sharing options...
Tony Nijhuis Posted January 31, 2007 Share Posted January 31, 2007 Joao, I think you could fit ic engines, something like the small 12 size thunder tiger or the Hornet engine that J Perkins import. Both are tiny and have rc carbs. Should be enough room for a 2oz tank and a micro throttle servo in each nacelle.Hope this helpsTony Quote Link to comment Share on other sites More sharing options...
Joao Alves Posted January 31, 2007 Author Share Posted January 31, 2007 Hi Tony.Thanks for your reply.In terms of thrust, the .12 gives same power as the 400 size motor?Regards Quote Link to comment Share on other sites More sharing options...
Balsa Basher Posted March 29, 2007 Share Posted March 29, 2007 Hi, Work on my B17 is going ok! I have a couple of questions regarding the Finishing.1) I have tried to paint Silver acrylic car paint directly onto the vac formed turrets and find that it peels off once dry if the turret is flexed. Any help on what I'm doing wrong and the preparation I should be using before applying the top coat?2) ESC questions. I have decided to go the Li-po route and in the next few weeks will be looking for a suitable 50A speed controller. Any help on part numbers and where to buy them would be great help? 3) 5s3p Li-po packs. Although I have not contacted any of the specialists advertised in the RCM&E, looking through the various listings I can only find details upto 5s2p packs. Is the 5s3p pack special (and expensive)? Quote Link to comment Share on other sites More sharing options...
Tony Nijhuis Posted April 2, 2007 Share Posted April 2, 2007 Before painting on to plastic of any sort, you must 'key' the surface with Wet n Dry or similar....Puffin models do a 50A plus, speed controller so give John Emms a call.As long as you have the 5s (18.5v) then it doesn't matter about number of 'p' Tony Quote Link to comment Share on other sites More sharing options...
Balsa Basher Posted April 4, 2007 Share Posted April 4, 2007 Hi Tony, Many thanks for your reply. I will give it a go! As soon as the paint is dry I will put a few pics in the Gallery and if all goes well one in flight!Once again many thanks. Quote Link to comment Share on other sites More sharing options...
