Problem with programming flaps X10 and E-Soar plus
Stephen Belshaw
I'm trying to programme a sailplane using Mike Shellim's E-Soarer Plus for OpenTx, I've successfully used it before on a couple of models. This time I'm using a Frisky X10 rather than my usual X9D+ but the principles (I think) remain the same, however I'm having difficulty in setting the flaps up. In calibration mode all works fine, both flaps are synchronised and have the full range of movement but, as soon as I come out of calibration and in to flight mode, the flaps won't return to their neutral position instead parking themselves at around 20 degrees.
I've re-done the process a number of times but cannot resolve this issue, everything appears to be ok on the TX and all in accordance with Mike's settings, range of servo travel etc.
I'd email Mike but his contact link from the website is not functioning, so hoping someone on here could throw some much needed light on it.
