John McClean Posted May 9, 2007 Share Posted May 9, 2007 I'm balancing my Fairchild PT-19 (from Seagull Models)and the instructions say 6.5 cm - 7.5 cm back from the leading edge of the wing measured at the "wing tip". Is this right, as most CGs are at the "wing root"? Has anyone got some advice please? Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted May 10, 2007 Share Posted May 10, 2007 John, try giving UK distributor J.Perkins a call, they should be able to help. 01622 854300 Quote Link to comment Share on other sites More sharing options...
geoff dales Posted May 10, 2007 Share Posted May 10, 2007 http://www.seagullmodels.com/sach/11.pdflink to manual above Quote Link to comment Share on other sites More sharing options...
Ken Tarran Posted August 20, 2019 Share Posted August 20, 2019 Hi John, Were you able to get to the bottom of the C of G issue that you raised in your post? I have the same model and am at the point of checking the C of G and also find it most unusual to measure at the wing tip. Quote Link to comment Share on other sites More sharing options...
