Marcus Posted May 15, 2007 Share Posted May 15, 2007 I have decided to purchase a PILOT models aerobatics plane. http://www.sloughrc.com/pages/Products/Aircraft/SRCM-AircraftScale_Pilot.aspIm still undecided between the Sukhoi and the CAP......Anyway, what engine should I use? I know it says .10 but I have seen ads for aerobatic 48" with a 46 class. Im thinking a 15. Or a 30 size four stroke. Anyone know where I can get a cheap one?Marcus Quote Link to comment Share on other sites More sharing options...
Patrick Adams Posted May 16, 2007 Share Posted May 16, 2007 Try ebay there are loads of four strokes on there. Quote Link to comment Share on other sites More sharing options...
Alistair Taylor Posted May 16, 2007 Share Posted May 16, 2007 Marcus I've been using a Magnum GP10 in a V-bat flying wing, which is about 60" span.It is spritely on this engine, and I would expect your Pilot model to be the same if it is built light enough (it's also very frugal on fuel!).I've no idea how good the balsa is in these kits (I've been tempted to get one but haven't yet), but examine the balsa in the kit with weight-saving in mind and replace any wood (particularly at the tail-end) that seems a bit hard/heavy.Us thin cyano, and only epoxy (sparingly) where needed and it should be ok.Use a 7x4 - 7x5 prop with the 10 and you should be fine. Go to a 7x6 if you have a runway to fly from (slower initial acceleration but higher top speed once airborne).This chap;www.radiocontrolmodels.co.ukhas an O.S. 10 for sale for £24. Engines I've bought from him in the past have been good.Hope this helpsAlistair Quote Link to comment Share on other sites More sharing options...
Marcus Posted May 18, 2007 Author Share Posted May 18, 2007 Thanks Alistair! Im off to the model shop tomorrow so I will add the prop to my shopping list!If (WHEN!) I get the kit, I'll start a picture thread for you if you want. I still can't decide though..... CAP 232 or Su31 ? (The hard work I make myself do!) I prefer the Su31, but only just. Quote Link to comment Share on other sites More sharing options...
Marcus Posted May 20, 2007 Author Share Posted May 20, 2007 Well, I've bought it, and I'll put up pictures and maybe a build diary if you want. Quote Link to comment Share on other sites More sharing options...
Alistair Taylor Posted May 21, 2007 Share Posted May 21, 2007 MarcusThat would be very informativeThanksAlistair Quote Link to comment Share on other sites More sharing options...
Marcus Posted May 21, 2007 Author Share Posted May 21, 2007 I have bought the Extra, and an OS15 Quote Link to comment Share on other sites More sharing options...
Marcus Posted May 21, 2007 Author Share Posted May 21, 2007 I may not put up a build diary, depends what permission I get from my parents. Quote Link to comment Share on other sites More sharing options...
Marcus Posted May 21, 2007 Author Share Posted May 21, 2007 What prop would an OS26 4 stroke require, and would it be suitable? There is a nice one on Ebay. Quote Link to comment Share on other sites More sharing options...
Marcus Posted June 6, 2007 Author Share Posted June 6, 2007 BUMP!I have purchased the Extra. What should I cover it with? Quote Link to comment Share on other sites More sharing options...
Alistair Taylor Posted June 7, 2007 Share Posted June 7, 2007 Sorry MarcusGot a bit caught up in the Lipos discussion.If you look here;http://www.osengines.com/manuals/index.htmlyou should be able to get a manual for the OS26, if it's still up on Ebay.If you're using a glow motor on the xtra, you'll be OK with solarfilm, although profilm will give you a better finish, and will not wrinkle in the sun. If you really want to keep the plane light, you could try one of the lighter weight films or other coverings.Add some colourful solartrim and you sould have an attractive model. Top tip - to position the solartrim, first wet the area where it is to go with soapy water. The solartrim floats on this initially, and can be accurately positioned. As the water dries, the trim sticks to the surface tighter than a limpet.(I'm probably telling you stuff you already know, as I see you've already built a cub to train on...how's the sunderland progressing :o)AlistairT Quote Link to comment Share on other sites More sharing options...
Alistair Taylor Posted June 11, 2007 Share Posted June 11, 2007 MarcusHow's the build of the Extra going?I spent saturday evening building....after crashing at about 2pm :o)AlistairT Quote Link to comment Share on other sites More sharing options...
Marcus Posted June 17, 2007 Author Share Posted June 17, 2007 This is the build diary:http://www.modelflying.co.uk/forum/forummessages.asp?dt=4&UTN=787&V=6&SP=I have got a brand new OS 15 2-stroke with a graupner prop. Quote Link to comment Share on other sites More sharing options...
