Andy Pickford Posted May 30, 2009 Share Posted May 30, 2009 Well went off to the field with my new Hanger 9 Showtime 50 with an OS max 55 ax in the front. I tweaked the engine on the stand and it ran really well got it all sorted. When i built up the courage it was time to put it where it belonged. Took off got the trims sortedthen i heard it start to cough and splutter!!! I wont tell you what i said as i would get told off!! Anyway i got it down in one piece. When i looked at the fuel line to the carb there was loads of air bubbles in it! So i wondered if there was a leak somewhere. When i got home i took the tank out, filled the sink put a fuel bung in one line and blew in the other. Nothing it is airtite. so i was thinking that the tank was vibrating about and bubbling the fuel up in the tank. So ive packed more sponge round the tank to make sure it doesnt move about!! I'll try again tomorrow. Quote Link to comment Share on other sites More sharing options...
Stefan Hafner Posted May 30, 2009 Share Posted May 30, 2009 Hi Andy I would have a look at the clunk tube in the tank, especially aroung the area where it attaches to the tank bung. I't possible that there is a hole in the line there letting the air in. Quote Link to comment Share on other sites More sharing options...
Andy Pickford Posted May 30, 2009 Author Share Posted May 30, 2009 Cheers Stefan ill go take all that sponge out!!!!! Quote Link to comment Share on other sites More sharing options...
Andy Pickford Posted May 30, 2009 Author Share Posted May 30, 2009 Ive checked the clunk fuel line and no leaks there either. Its all back together and i'll try again tomorrow!!! Quote Link to comment Share on other sites More sharing options...
Ross Clarkson Posted June 15, 2009 Share Posted June 15, 2009 Andy, When you have the engine running as you wish, do you apply full power and hold the aircraft nose up to see that the needle settings are ok for high angle of climb flight? It might be that the needle settings are ok in level flight (Setting up on the ground) but as you climb it starves the engine of fuel because you are too lean. Quote Link to comment Share on other sites More sharing options...
Andy Pickford Posted June 15, 2009 Author Share Posted June 15, 2009 Ross I checked it all out on the ground nose up at full power and everything was fine before i flew it. Ive changed the whole fuel tank and everything is great now. Cheers Andy Quote Link to comment Share on other sites More sharing options...
flytilbroke Posted June 15, 2009 Share Posted June 15, 2009 Might just have gotten the fuel tubes crossed (i did that recently   Never know now though. Nice to know it is sorted. Quote Link to comment Share on other sites More sharing options...
