David Stembridge Posted July 2, 2007 Share Posted July 2, 2007 I have bought some fuel and found that the container says that it is a car mix (monster fuel). Will this be ok to us in an aero engine(OS46). To me an engine is an engine! but what do I know. There must be a difference other wise why label it. Any advice would be gratefully recived. David. Quote Link to comment Share on other sites More sharing options...
Andy Green Posted July 3, 2007 Share Posted July 3, 2007 Hi DavidMy take on this is it depends on the make up of the fuel and how it compares to that required by your engine manufacturer.Does it contain castor oil or is it fully synthetic, and how much nitro does it contain. To my knownledge car fuels tend to be higher nitro, and car engines are designed to need that. If you run it in an aero engine you may find you get pre ignition, you will hear a sort of harsh banging noise when running.As to the synthetic / castor debate, I have recently move to fully synthetic (ProSynth 5%) and found it to be brilliant.Andy Quote Link to comment Share on other sites More sharing options...
David Stembridge Posted July 3, 2007 Author Share Posted July 3, 2007 Thanks Andy.Both my usual and this new fuel are 10% nitro. I am unsure about the oil.I think I am being a bit over careful on this but having your money 2 or 3 hundred feet up does that to me!!!!!! David Quote Link to comment Share on other sites More sharing options...
Andy Green Posted July 3, 2007 Share Posted July 3, 2007 10% doesn't seem that high, I would be tempted to try it with maybe a cooler plug.The only thing to be wary of is the oil content, If you can be sure its no less that 18-20% you should be OK.But it's not my money up there.On a slightly different note, As modellers we tend to be a tight bunch, and use and reuse all the time. Maybe the words discretion and valour should spring to mind and just buy some more. (I can hear the screams from here)A Quote Link to comment Share on other sites More sharing options...
