seagull Piper Cub
John  Tee
enjoyed putting this model together. The undercarriage is prebuilt from piano wire with strong springs for spreading the load, the model is fairly heavy for its size. on my first flight the model was quite badly out of balance so a landing was made. i missed the strip and landed in some loose soil used to fill a rut by the strip, this acted as an emergency brake stopping the model very quickly and taking out the u/c. on first inspection  not much damagejust broken joints on the various u/c members. back at the pits I found that two joints had sprung but the main member that the wheels fitted onto had snapped (approx 8 swg.) further inspection showed that all the various wire bits were spot welded together and where the break was coincided with a spot weld. It looks as if the welding had burnt into the wire leaving a weak spot.
