First low winger
Mike Churchill
I recently passed my A Cert with high wing trainer so now moving to low winger. After reading an article in RCME about converting a SpeedAir 40 to electric I thought it would be a good model for my first low winger but in its original IC form.
It is now ready to fly but I need to be sure about a couple of points:
a)I have installed a JEN 37 (Should have power of 40 ?) Is that enough to get off the ground and fly like a trainer?
b)The CG is a tad forward of recommendations (a few mm). Is that a bad thing and should I try to get an exact balance? The trouble is if the answer to a) is I need a bigger engine the CG will be even further forward!
Advice would be appreciated
Excuse me, but what you call the CG isn't .What you are all talking about is fore & aft only.
.If your servo's/battery /everything else are more or less above the thrust line of the engine you will need some dihedral to compensate especially for the "CG" as you call it on a trainer.The CG of any 3-dimensional object can only be located by considering all 3 dimensions .So the CG must be located along all 3 axes. Keep the CG BELOW the centre of lift(trainers only)) whether it's high or low wing and the stability (for a trainer )will be OK.It doesn't matter which configuration. To those that might disagree - Imagine a low winger with 20 degrees of dihedral ? Wouldn't it be better than a high winger with anhedral wings ??
Many thanks for that. I don't think I have a problem with regard to balance on the axes other than fore and aft. I understood the fore and aft balance point to be fairly critical as it is the one usually specified by model designers. Perhaps I used the term CG loosely?
Hi Mike Of course it's critical_ the fore & aft thing , but I think you've missed the point ,I think (correctly) that High wing Versus low wing is an issue based on the CG above or (& I mean)ABOVE "the datum come -thrust line" otherwise it will fly better inverted .Look at how birds fly ! Maybe we could start a thread on high versus low wing thread & I will start by saying that it all depends what you really want .A totally stable flying m/c upright or inverted OR a 2nd model with a low wing THAT RESPONDS LIKE A HIGH WINGED CESSA type thing that I thought you were after
info about for your 2nd model !?
