andrew wise 2 Posted October 30, 2009 Share Posted October 30, 2009 I'm not sure if this is the right place for this question but hey! here goes. I have a 80" Mick Reeves Hurricane It was given to me I guess it was built a few years ago. It is fitted with mechanical retracts no servo, I'm not sure of the all up weight of the aircraft, Can anyone help with what servo I should fit etc. Changing to air retracts I do not belive is an option due to the contruction of the foam core wing around the retract bay I think I have to go with what I've got if possible. Thanks for your help Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted October 30, 2009 Share Posted October 30, 2009 Usually a purpose designed (non proportional) retract servo would be used - something with sufficient torque to ensure a full operation of what could be quite heavy loads.Its also best to deploy a separate battery for the retract servo, to prevent a stalled leg /servo draining your radio battery. Quote Link to comment Share on other sites More sharing options...
andy watson Posted October 31, 2009 Share Posted October 31, 2009 Mick Reeves do sell a retract servo- but I think it's about £50, I guess it's for their larger models. They should be able to tell you what requirements the servo should have though, and you will then be able to go through the regular suppliers to get one. Quote Link to comment Share on other sites More sharing options...
