why did I put 3s Lipo in the York?
Yorkman
The York originally flew with 2 1900 7 cell nicad packs-and 'performance' was marginal at best-though the MTOW take-off runs were very scale!-so last year I upgraded to Lipo and UBEC as discussed elsewhere on this forum...but, musing the other day, quick calculation in head 7x1.2=8.4volts from the nicad packs...same as a 2s lipo...why did I go for a 3s? Performance is now 'sparkling' in contrast to before, but the speed 400s (7.5 volt?) must be suffering the extra voltage-indeed, I've replace one that went duff already-so why don't I use a 2s instead? And save a bit more weight? Or get a bigger one, or two in parallel and get some decent flight times?
And before you all start, going brushless is on my 'to do' list, but the major surgery involved-de-skinning the mainplane-means I'm in no rush-she flies just fine now and is hardly over-worked-3 or maybe 4 flights this year!
Posted by Frank Skilbeck on 13/11/2009 14:37:45:
So rather than replace your 400s with 400s when they burn out, try a 480.
 Except I'd have to change all four....or at least a pair!
Will shortly have 2x2s lipo packs for the Mossie, so will trial fit in the York and do some thrust/taxi tests and see how she goes.
