fly boy3 Posted November 28, 2009 Share Posted November 28, 2009 Hi all,I am currently using the sandwich method of cutting balsa ribs -(1st time). Is there an accurate way of removing the spar slot balsa after cutting the verticals, while they are still bolted together. There are 4 slots per rib. Thanks Fly Boy 3 Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 28, 2009 Share Posted November 28, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted November 28, 2009 Share Posted November 28, 2009 Hi FB3, if you have finished the shaping of the ribs it would be safe enough to unbolt them and make the spar slots in your templates. Then bolt the whole lot together again and use a small square file to finish off the slots. That's how I do it anyway, I'm sure there will be better ideas out there somewhere. Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted November 28, 2009 Share Posted November 28, 2009 You just pipped me to the post there Eric! Quote Link to comment Share on other sites More sharing options...
