Phil 9 Posted January 1, 2010 Share Posted January 1, 2010 I just got hold of some printed pattern Monokote covering. The problem is it only will cover the top of the model. I need some one colour covering for the botom. the problem is I cant find Monokote covering in the UK (only on US based sites) Can I use a two different makes of covering on the same model. (will the different temperatures required cause a problem). Or can someone tell me where I can get Monokote in the UK. Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted January 1, 2010 Share Posted January 1, 2010 If you are covering upper and lower in differnet products then you should not have any issues. What I would do is take a small sample of your pattern film with you to the shop you buy the film from amd try and get a covering of similar weight / thickness. If you go to a decent shop, the guys behind the counter should be able to assist in getting a compatible product Quote Link to comment Share on other sites More sharing options...
