Mark R Posted March 19, 2010 Share Posted March 19, 2010 Ow dooo all, i bought one of these to replace my Corsair, pilot inability! I have the P-51 version which is excellent, helps to have an oversized leccy motor and 3 cell lipo , the problem i have with the Thunderbolt is its lack of manouverbility, wont loop without a 'power dive' to help it at the beginning and as for rolls, pahh seen better rolls on a British Rail train. Have everything at 100%, whereas the P-51 is on about 60% and does everything well, replaced the the servos and the motor is good and pulls well, i use 2 cell 1800 lipo in it, but its just seems sooo sluggish and unwilling. Has this anything to do with the fact the body could hide a suma wrestler behind it? Seems very ermm bulbus to say the least? Any ideas? Why is it raining why why why Quote Link to comment Share on other sites More sharing options...
scott cuppello Posted March 21, 2010 Share Posted March 21, 2010 You only state that you are using 2s....what motor and prop? I have to say, 2s wouldn't be my first choice. Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted March 21, 2010 Share Posted March 21, 2010 I must admit I was expecting a 3S lipo as a minimum Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 21, 2010 Share Posted March 21, 2010 Either a typo..... or that is indeed the reason its so slow Quote Link to comment Share on other sites More sharing options...
Mark R Posted March 22, 2010 Author Share Posted March 22, 2010 Hi all, thanks for responses........its using same negine as was in my P51 before i ahem upgraded it.....P51 pulled hard and was fine using 2 cell 1800.....friend who had Corsair was using an 850-1100 i think, definately smaller than battery i am using......its more the lack of wilingness to roll or loop......new servos, checked rate settings etc but just dont wanna do it Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted March 22, 2010 Share Posted March 22, 2010 All my experience of Thunderbolt models is that they fly well, and the shape is nothing like the draggy issue it might appear. None have needed much in the way of throws, either. The nearest to yours I have owned was an EFlite foamy, on the original "low power" brushed motor............about as aerobatic as warbird sized surfaces possibly come, without excessive throws. Floaty too with a surprising glide. Consecutive loop all day on 3/4 throttle, roll so fast if allowed only ailerons required to keep level. Only you know how much punch you get from the motor/battery combination, does it drag itself out of your hand held 30 degrees up (!) without a throw or do you HAVE to chuck it.............if you have to chuck it hard to get it away then yes, it's most likely that combination (you still have not said what the motor is!!) is not helping at all. It's NOT the battery size alone that matters, it's the match to the motor requirement. The battery IS GOOD, isn't it??? It might have sagged between the P51 and it's new plane??? Personally, the ONLY things I have on 2S now are a (very) few tiny foamies. I use 3S on pretty much everything from 300mAh upwards. You can always throttle back!!! Not convinced that 2S is the problem per se though provided the motor matches it!! Quote Link to comment Share on other sites More sharing options...
Mark R Posted March 22, 2010 Author Share Posted March 22, 2010 Ok folks sorry not to get back sooner..... specsXtra 2826/15 motor, can handle 2-3s lipoAPC 9x6 elec propMystery 30A BEC ESC could probably go to a 10x6 prop tho not 100% sure, all props sizes are from a model shop i trust.....tho i am sure there will be some going tsk tsk not right etc.Used same engine and set up on P51 and the Corsair too. All batteries are in good nick, charged before i fly and when is over balanced charged. Tho some reckon you should leave them 1/2 charged til your ready to use them. Not done that in the 3-4 years i have been using Lipos (Trex 450 heli) not had problems with batteries. Launching is just over 3/4's throttle and i launch myself so its a throw but not a massive heave! Its not so much power i am looking it, its it lack of 'throwability', now i know it does say its a 'docile' flyer, but....... Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted March 22, 2010 Share Posted March 22, 2010 Looking at the spec Mark this is only a small motor...max current is 9A (60 sec) so if we assume you are pulling this 9A max & we assume about 7 volts for your 2S battery then that is... er.....63 watts. Not a lot!!!! Going up to a 3S battery for the same current would just about get you to 100watts which would be much better....you'd probably need a much smaller prop though to keep the current under the 9A limit Do you have a wattmeter......if so what power does say you are consuming? (If not...why not???) Don't know this model but I understand that the Alpha range are very good fliers..... Quote Link to comment Share on other sites More sharing options...
Mark R Posted March 22, 2010 Author Share Posted March 22, 2010 Ermm got a 'what' meter ...... cheers for the info Steve will try a 8x6 prop and slug 3s thru it. Alphas do fly really well, which was fy i was surprised at lack of throwability in this one, could just be me, used to throwing the P51 one around, as they say all models fly differently. Next up is the Phase 3 F-16......once i am 2.4ghz......Dear Easter Bunny s*d the egg gimme 2.4 pwease Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted March 22, 2010 Share Posted March 22, 2010 MMM, yes, well............... SpecificationWeight:48gDimensions:28.8x26mmNiCad/Ni-MH:6-10 cellsLiPo:2-3 cellsOperating:4-8ATurns:15RPM per Volt:1100Current at Max Effic:9A/60sShaft dia:3.17mm So that's 8 Amps, max operating................on a motor weighing 48g. Hardly staggering figures. As a comparison, my GWS Corsair has a really cheap SP2212-10 driving a 8x4 and gives 130 Watts, flying around on half throttle and being very nimble with it ....and here's the killer, that's from only a 1000mAh 3S. A2212-10 (140W) 1400Kv SP Brushless Outrunner Motor Specifications: * Kv: 1400 (Revs per volt) * No load current @ 10v: 0.5A * Voltage: 2-3S Lipo or 6-10 Cells Ni-xx * Max Efficiency: 80% * Max Current: 16A (60secs) * Cont Current: 12-15A * Dimensions: D27.5 x L30mm * Shaft diameter: 3.17mm * Weight: 47g * Internal Resistance: 90 mÙ Now, Alpha models are very very lightweight (I have the Beaufighter currently), and there is no good reason why the Jug should not be "fleet of foot" as it were. You do have to remember though that the prop wash is masked by the big fat nose...........so allow for that in prop sizing!!! Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted March 23, 2010 Share Posted March 23, 2010 Yeah I thought it looked a pretty disappointing motor too Dave............not cheap either. Quote Link to comment Share on other sites More sharing options...
