Phil May Posted April 5, 2010 Share Posted April 5, 2010 I'm in the early stages of building Peter Miller's Wattsdog. It is a 41"vintage style electric model, which should weigh approx' 21 oz. I have a couple of tower pro sg 90 servos. They are 9g , 1.6 kg micros. Would these be ok to use for the elevator and rudder or would they not be up to the job . Any ideas on this please. Thanks . BP Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted April 5, 2010 Share Posted April 5, 2010 Personally I think they would be fine. Quote Link to comment Share on other sites More sharing options...
Phil May Posted April 6, 2010 Author Share Posted April 6, 2010 Thanks Bruce. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 8, 2010 Share Posted April 8, 2010 Wattssdog is very slow and docile. They would be more than enough for the model. Quote Link to comment Share on other sites More sharing options...
Phil May Posted April 8, 2010 Author Share Posted April 8, 2010 Thank you Peter. Quote Link to comment Share on other sites More sharing options...
Mowerman Posted July 9, 2010 Share Posted July 9, 2010 Another query on servos. I am building 'American Nightmare' Converting to electric (2 x 200watt) do you think 9g servos will cope? Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted July 9, 2010 Share Posted July 9, 2010 Mowerman, a lot depends on the model (size of control surface etc) & what you intend to do with it (gentle flying, 3D stick banging etc)......I have 9g servos in my Seagull Extra EP (42" span about 2lb weight & huge control surfaces....fitted with a 400 watt motor) & they have been fine although I did get a bit paranoid & replace the rudder & elevator servos with these. 14g...2.2kg/cm torque, metal gears & less than 8 USD. Certainly it is always best to over than under rate your servos...... Quote Link to comment Share on other sites More sharing options...
