Tony Smith 7 Posted April 8, 2010 Share Posted April 8, 2010 I'm just assembling one of these, which will be my first electric model. Anyone here have any experience with these? Edit - I should add that the one that has me scratching my head a little is how to stop the aileron control rods fouling the rudder and elevator servos. Edited By Tony Smith 7 on 08/04/2010 08:41:46 Quote Link to comment Share on other sites More sharing options...
Tony Smith 7 Posted April 16, 2010 Author Share Posted April 16, 2010 Well its all assembled, trimmed and flight tested now. No significant problems, but I guess it needs a bit more tweaking than suggested by the adverts. The control fouling was resolved with a little strategic bending of the aileron push-rods. Edited By Tony Smith 7 on 16/04/2010 08:56:36 Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted April 20, 2010 Share Posted April 20, 2010 Not really a model I've come across Tony, any pics? Quote Link to comment Share on other sites More sharing options...
Tony Smith 7 Posted April 20, 2010 Author Share Posted April 20, 2010 Dealer's photo of the complete plane .... Elevator/rudder servo fitment ... Receiver and ESC (arming switch on port side of fuselage) 1100mAh NiMH power pack under the canopy. Brush motor not visible, two blade folding 6x3 propeller ... Aileron servo and linkages on the underneath of the wing .... No-frills 4 channel 35MHz transmitter ... I'm sure everyone could have a field day finding fault with the model, but the fact is that when assembled with a bit of common sense it flies OK. CofG even comes out more or less right without fiddling around. The worst thing really is the instructions, some of which are hilarious, for example the low voltage warning light is described as "The low pressure reports to the police the light". In the assembly instructions plugging in the aileron servo is "Insert electron adjust into the LCD oscillate" I accidently got the throttle channel reversed, and sorting that out I found the reversing switches weren't correctly described in the instructions or on the transmitter ...Function TX Label InstructionsThrottle CH1 Rolling Yawing TelevisionAileron CH2 Pitching RudderElevator CH3 Motor Power ElevatRudder CH4 Yawing Rolling Aileron Edited By Tony Smith 7 on 20/04/2010 19:50:05 Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted April 20, 2010 Share Posted April 20, 2010 Ah ok, reminds me of the old Wattage Hawk of about 2001 vintage and latterly the Graupner Terry. Probably quite a nippy little thing? Quote Link to comment Share on other sites More sharing options...
Tony Smith 7 Posted April 20, 2010 Author Share Posted April 20, 2010 Yes, quite nimble although I have the control throws set quite short at the moment. There's a long thread on another site about the plane, including all sorts of modifications such as beefy brushless motor, fancy batteries and aileron upgrades. TW-742 Sky Hawk [Official Thread] Quote Link to comment Share on other sites More sharing options...
Tony Smith 7 Posted April 20, 2010 Author Share Posted April 20, 2010 That Graupner Terry looks like its rudder/elevator, rather than 3 axis if I read it right? I was set on ailerons. I found a few planes like that which looked OK at first glance, but then I thought they couldn't really work that well with rudder and almost no dihedral. Could just be my prejudice of course. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted April 20, 2010 Share Posted April 20, 2010 Looks like a handy go-anywhere sort of model..... don't think much of the wheels that chap's added... Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted April 20, 2010 Share Posted April 20, 2010 Yup, three-channel, the Terry is simply superb and flies well without ailerons (in mini hotliner guise) a clever little aeroplane that one. I'm told that adding ailerons doesn't add anything much to the handling. Edited By David Ashby - RCME Administrator on 20/04/2010 20:01:50 Quote Link to comment Share on other sites More sharing options...
