Hogster Posted June 29, 2010 Share Posted June 29, 2010 Hi all, I have recently acquired a second hand ARTF trainer. It has not been assembled very well IMHO and one of the major problems is that epoxy glue has been used to secure the hinges. In itself maybe not so much of a problem but they did a pretty messy job of it. The glue has oozed all over the hinge to such an extent that it is restricting the movement of the control surfaces. I have heard that epoxy can be dissolved with nail varnish remover or paint stripper. Does anyone have experience of this or can suggest an alternative method of curing the problem? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted June 29, 2010 Share Posted June 29, 2010 I think I would avoid chemical solutions as they could affect the fixing of the hinge too!Could you not just persistently pick away with some tweezers, scalpel blade etc? In a similar very severe case some years back, I resorted to cutting right through the hinges, cut off flush, and re-fitted my own in slightly different positions along the control surfaces. Edited By Tim Mackey - Administrator on 29/06/2010 11:25:10 Quote Link to comment Share on other sites More sharing options...
Hogster Posted June 29, 2010 Author Share Posted June 29, 2010 Hi Tim, I have tried picking at them with a scalpel. But it really is laborious. I have considered cutting right through and refitting new ones. It might be the best option on the ailerons. But there isnt` much room to reposition them on the elevator and rudder. Of course if I can dissolve all the epoxy and remove the hinge that way, I think that would be ideal. Quote Link to comment Share on other sites More sharing options...
Shaun K Posted June 29, 2010 Share Posted June 29, 2010 Hi Hogster, I had the same issue with an ARTF trainer and went with Timbo's solution - new hinges in new positions. It all worked out fine. Good luck, Shaun K.Edited By Shaun K on 29/06/2010 12:50:41 Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted June 29, 2010 Share Posted June 29, 2010 Epoxy can be removed as you suggest with nail varnish remover (acetone,cellulose thinners) but only before it has cured. One it has hardened it seem impervious to chemical removal. It can be softened by warming it up but if you get it too hot it gives off noxious fumes. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted June 29, 2010 Share Posted June 29, 2010 it can also be removed with a Dremel! Quote Link to comment Share on other sites More sharing options...
Hogster Posted June 30, 2010 Author Share Posted June 30, 2010 Thanks for the advice chaps. I think i`ll try the dremel and then if it is still a problem i`ll cut them out and replace with new. I prefer pinned hinges anyway. Quote Link to comment Share on other sites More sharing options...
