lightning 759 Posted August 8, 2010 Share Posted August 8, 2010 hi your advice is required please. converting a seagulls models pc9 gone is the 52 fourstroke to be replace with a TR 42-60C 500Kv Brushless Outrunner what i need to know please is will i need a 4cell or 5cell lipo & wot prop ?? was hopeing to go for a 4cell pack as fuz is quite norrow but now confused after reading commets about it, this is new ground for me please help many thanks andy Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted August 8, 2010 Share Posted August 8, 2010 You could use a 4 cell, but will need to ensure the prop is large enough to produce the power you need - whats the AUW - around 5 - 6lb ? If so aim for about 500 watts minimum so on 4s battery thats 35 -40A maximum which is do-able with a good capacity battery like maybe 5000m/a Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted August 8, 2010 Share Posted August 8, 2010 I have the TR 42-50A 700 Kv and run it with a 13 x 6 or 12 x 6 on a 4s (3200 mah) in a 63" E Flite DH Beaver, 38 amps and 600w, pretty much on par with a 52 4 stroke. With a 500 Kv motor ona 4s you'd need more pitch to keep speed up, I just ran Drivecalc (www.drivecalc.de) and on a 4s battery needed a big prop (14 x 12) to get over 500w. So you'd need either more volts (i.e. 5s battery) or a higher Kv motor to run on a 4s battery. Download drive calc and put in some motor/prop/battery combinations to give you an idea, but I think you'd need to keep the diameter down to below 13" for ground clearence. Quote Link to comment Share on other sites More sharing options...
