Richard Putnam 1 Posted August 23, 2010 Share Posted August 23, 2010 Hi, I am about to embark on a small 40" span electric aerobatic (I hope) design. But on a recent electric build, I felt let down on the covering which for a light balsa construction seemed to be like covering it with a tarpaulin! My IC designs seem fine with basic Solarfilm but I am after something lighter. Any ideas would be appreciated. Richard. Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted August 23, 2010 Share Posted August 23, 2010 Solar span? D Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted August 23, 2010 Share Posted August 23, 2010 Solarfilm should not be too heavy. This is my 36inch span model built from a rcme free plan. Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted August 24, 2010 Share Posted August 24, 2010 Hi Richard, I agree - Solarfilm should be fine for a 40" span electric model, but if you want something lighter you could try Solite or Litespan which are also made by Solarfilm. Have a look on Solarfilm's web site for info. SolarfilmEdited By Richard Wood on 24/08/2010 08:05:31 Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted August 24, 2010 Share Posted August 24, 2010 solar film will prob be alright but solite is very very good you have to apply an adhesive to the airfame but it is very tough and easy to apply Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 24, 2010 Share Posted August 24, 2010 How about Solarfilm Litespan. You cover with the aid of Balsalock adhesive and an iron in the same way as Solarfilm . It has the advantage that it can be doped to make it slightly tighter. For a glossy finish a little heavier you could use Solarilm Fibafilm. Similar to Litespan but glossy and quite a lot stronger. You need to use that with balsaloc as well and it pays to sandpaper off the gloss where one layer is stuck down over the previous one.Edited By Peter Miller on 24/08/2010 09:11:03 Quote Link to comment Share on other sites More sharing options...
Mowerman Posted August 24, 2010 Share Posted August 24, 2010 Go back to the traditional system. Tissue and dope. Or you could try mylar and tissue. (Freeflight supplies) Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted August 24, 2010 Share Posted August 24, 2010 Yeah, Lightspan. Thats what I meant. D'oh! But I agree, film should be the stuff for the job. D Quote Link to comment Share on other sites More sharing options...
Richard Putnam 1 Posted August 24, 2010 Author Share Posted August 24, 2010 Thanks for all your replies . I have read the blurb on litespan the only problem is I imagine it is a matt finish as they say it will take paint? Looking at the Solarfilm website Fibafilm looks interesting has anyone tried it? Richard. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 25, 2010 Share Posted August 25, 2010 paint on litespan is going to put weight back on for a lot of trouble. go with transparent solarfilms - they are lighter than solid colours and just as easy to put on john Quote Link to comment Share on other sites More sharing options...
Richard Putnam 1 Posted August 25, 2010 Author Share Posted August 25, 2010 Hi John, I have some transparent Solarfilm and it would look pretty good and show off all the lightening holes etc. Good thinking. Richard Quote Link to comment Share on other sites More sharing options...
Guest Posted August 26, 2010 Share Posted August 26, 2010 Richard, red is best - the model visibility cannot be beat - and the red colour shows all the way up as high as you want. Similarly with antique ( vintage ?) red solartex which is not as opaque as the solid red. John Quote Link to comment Share on other sites More sharing options...
Richard Putnam 1 Posted August 26, 2010 Author Share Posted August 26, 2010 Are, but what about inverted John? I have a 60" sports model with big parallel wings and that was a curse first of all until I added some stripes to the underside. That model is in transparent yellow (Antique?) maybe I could try yellow top and red underside? Thanks for your suggestion John your idea is what I will go with. Richard. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 26, 2010 Share Posted August 26, 2010 I had stripes on a goldberg super chipmunk until it rolled over into the ground when a strip came off and blanked an aileron - not enough heat applied sticking one film ontop of another. . Quote Link to comment Share on other sites More sharing options...
