Gavin Livsey Posted November 21, 2010 Share Posted November 21, 2010 Hi Folks, Just read in this months Mag that using your 35 Meg radio with the aerial down damages it. Most of my flying is still on 35 and I use the same Tx for my sim. Should this be a problem? What do you think? Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted November 21, 2010 Share Posted November 21, 2010 I must be honest I wasn't aware of the problem. I don't know for certain, but I think in most sims the Tx is in "slave" mode - like when actually buddying - in which case its not transmitting. As I say I'm not certain about that but I think it is so - maybe someone more knowledgable can confirm? For most users the biggest problem in lots of sim use is the buddy lead socket - which can work loose from repeated use in some trannies. THis can result in broken connections - and even effect the main board. If your bothered why not go on ebay a buy a cheap second hand 35M Tx - you can get them at really low prices at the moment. And a spare might not go amiss anyway! BEBEdited By Biggles' Elder Brother - Moderator on 21/11/2010 19:56:55 Quote Link to comment Share on other sites More sharing options...
Gavin Livsey Posted November 21, 2010 Author Share Posted November 21, 2010 BEB, Thanks. I have tried using an old Skysport 4 Tx, but it just doesn't feel the same as my regular trannie. I think you are right about the Tx going in to slave mode when connected. It makes sense I suppose. I am aware of the problems with the buddy lead socket. I tend to leave the trannie connected to my PC unless I'm actually out flying (which this year seems to be once every other week). Gavin Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted November 21, 2010 Share Posted November 21, 2010 HI Gavin, I've thought about this some more - I use an old Skysport 6 on my sim and it hasn't even got a crystal in it! So that one ceratinly isn't transmitting! BEB Quote Link to comment Share on other sites More sharing options...
Tony Smith 7 Posted November 22, 2010 Share Posted November 22, 2010 Same here, I understood that the loopback pins on the trainer cable (Hitec Optic) switch off the RF. Easy enough to test, I'll just see whether it controls a receiver when hooked up to the simulator. Quote Link to comment Share on other sites More sharing options...
Gavin Livsey Posted November 22, 2010 Author Share Posted November 22, 2010 Guys, Have just been playing with my simulator. Brought a model in to the room, switched it on and hey presto everything waggles when I move the appropriate stick. So, Tx IS transmitting when connected to the sim. Therefore, back to my original question. Is this going to damage my tx? Quote Link to comment Share on other sites More sharing options...
flytilbroke Posted November 22, 2010 Share Posted November 22, 2010 It could do, remove the Xtal, wrap the lead around the TX handle, which decreases risk of possible socket damage. Take care at any stage of removing/reconnecting lead and Xtal. Best alternative has already been mentioned, aquire another TX. Battery not required, at least in some sets. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted November 22, 2010 Share Posted November 22, 2010 Gavin what make is the Tx? if it's JR or Spektrum then leave the Tx switched off, when you plug in the trainer lead - that will bring on the Tx in buddy mode (i.e. not transmitting). If it's a Futaba, is there a crystal to remove? This will stop it transmitting, eliminate any possible damage to the RF transistors and will also make the battery last much longer. Just don't forget the crystal when you go flying. Quote Link to comment Share on other sites More sharing options...
Gavin Livsey Posted November 23, 2010 Author Share Posted November 23, 2010 Chris, thanks It's Futaba.I'll try it later without the Crystal. Quote Link to comment Share on other sites More sharing options...
