Terence Lynock Posted December 12, 2010 Share Posted December 12, 2010 Can someone explain the advantages of assimetric configuration such as the BV141?, why take out the cockpit and stick it out on the wing where it generates a lot of drag plus it must have been a very strange thing to fly with the piloten not on the centre line. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted December 12, 2010 Share Posted December 12, 2010 I suspect one of the advantages was that the designer had a dedicated boom for the technical services - engine fuel supply, electrics, hydraulics, control wires etc. - such that they didn't need to run these through the "living quarters". This would make routing simpler and have certain safety benefits. Also possibly cost/weight benefits because safety restrictions would be somewhat relaxed compared to if these systems had to run through the cabin. There may also be servicing advantages in such a set up because technical systems could be laid out in an accessable fashion - with no account having to be taken of crew access/comfort etc. Just a guess - but it would make sense. BEB Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted December 12, 2010 Share Posted December 12, 2010 TerenceIn the case of the BV141 it was designed as for observation duties so the configuration gave the pilot and observer a full view forward and down.By carefully playing around with the wings and tail Blohm & Voss got the centre of drag, thrust and lift in line with the CofG so by all accounts it flew quite normally. For the record the pilot of the twin Mustang was not on the plane centre line either! Quote Link to comment Share on other sites More sharing options...
001 Posted December 12, 2010 Share Posted December 12, 2010 The Reichluftsfahrtministirium (I love that word) in 1937 issued a specificaton for a short range general purpose aircraft to various manufacturers. Blohm & Voss thought that the best way of fulfilling the brief with a single engined aircraft that had excellent visibility all round for the crew was to put the crew in a cabin and the engine in another, so the main reasons were, one engine, maximum visibility. Apparently it flew quite well. But in the end, the Luftwaffe bought a two engined aircraft, the FW 189. I have a flying model of the Blohm & Voss BV 141. The C of G is between the cabin and the fuselage. There are other assymetric aircraft, configured that way for various other reasons.Edited By Richard Bond on 12/12/2010 19:06:56 Quote Link to comment Share on other sites More sharing options...
001 Posted December 12, 2010 Share Posted December 12, 2010 This is a photo of the model. Tried to insert it with my original post but AOL is being extremely obstructive at the moment. 54" wingspan, powered by Thunder Tiger 0.54 FS from plan by Nick Ziroli. Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted December 12, 2010 Author Share Posted December 12, 2010 I can understand the engineering advantages and the field of view beeing improved but both could have been accomodated by a twin boom config with a pusher prop, the problem with concentrating all services in one area is that should the aircraft be hit anywhere in that area more systems are lost. The FW 189 was a better aircraft in my opinion for the observation role but the BV141 must have had something going for it to be put into production. Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 12, 2010 Share Posted December 12, 2010 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bert Posted December 13, 2010 Share Posted December 13, 2010 Eric 'Winkle' Brown, in one of his books stated that the design evolved from the requirement to give the rear gunner an unobstructed field of fire. According to him, the idea was to flip the BV141 on its' side in a sort of knife-edge to achieve this. Bert Quote Link to comment Share on other sites More sharing options...
