Jeff Glasser Posted January 7, 2011 Share Posted January 7, 2011 Is there a build blog on here of Cyrils Stranraer? Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted January 7, 2011 Share Posted January 7, 2011 No Jeff, just some extra pics. Quote Link to comment Share on other sites More sharing options...
Jeff Glasser Posted January 7, 2011 Author Share Posted January 7, 2011 Thanks for that David, every little helps before I attempt a build! Jeff Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted January 7, 2011 Share Posted January 7, 2011 Nice one Jeff, post some piccies if you can Quote Link to comment Share on other sites More sharing options...
Jeff Glasser Posted January 7, 2011 Author Share Posted January 7, 2011 I will David, though it will be my first venture into using depron, so keep your fingers crossed! Jeff Quote Link to comment Share on other sites More sharing options...
P Smith Posted March 24, 2011 Share Posted March 24, 2011 Hi am building the stranraer from cyrill carr would be happy to upload photos for youas it is a complex buildhave built up to the nacells wich i am building out of foam water pipe tubing (tricky) Paul Quote Link to comment Share on other sites More sharing options...
P Smith Posted March 24, 2011 Share Posted March 24, 2011 Quote Link to comment Share on other sites More sharing options...
P Smith Posted March 24, 2011 Share Posted March 24, 2011 will post more as soon as i can the current status is that i have painted the fuz and completed the main wing sectionsbut the problem was getting pink foam so am using pipe foam which is just as good because it houses the 300 motors nicelly will post more pics as soon as i can cheers Paul Quote Link to comment Share on other sites More sharing options...
Jeff Glasser Posted March 24, 2011 Author Share Posted March 24, 2011 Great stuff P Smith, I have'nt even got the depron yet, but any help would be appreciated. I have been studying the plan quite a bit and your photos' have cleared up a couple of items. Where do you get Depron from? B&Q? Jeff Quote Link to comment Share on other sites More sharing options...
P Smith Posted March 24, 2011 Share Posted March 24, 2011 Hi Jeff got my depron on line from: http://www.depronfoam.co.uk/html/buy_depron.html b and q do sell a type of depron but its not the same hope this helps let me know if you need any more pics or info good luck with it regards Pau Quote Link to comment Share on other sites More sharing options...
Jeff Glasser Posted March 24, 2011 Author Share Posted March 24, 2011 Should that be 'Paul' ? Thanks for the Depron address. I did see something like it in B&Q but it did'nt look right so I left it alone. When you say 'pipe foam' do you mean the stuff that goes around the outside of water pipes etc.? Of course I, and I'm sure others would love to see more pics' Jeff Quote Link to comment Share on other sites More sharing options...
P Smith Posted March 24, 2011 Share Posted March 24, 2011 Hi Jeff yes you can get this from b and q i thinkit measures 5 cm from edge to edgeit fits a 300 quite nicely Paul Quote Link to comment Share on other sites More sharing options...
Jeff Glasser Posted March 24, 2011 Author Share Posted March 24, 2011 Excellent. Jeff Quote Link to comment Share on other sites More sharing options...
Raymondo Posted April 21, 2011 Share Posted April 21, 2011 Hello all I have just complete the fuselage For the Stranraer with Depron (my first attempt with Depron) quite easy to work with. Does anyone know where to obtain the 3 bladed props about 140 mm dia. I have searched all the usual websites without success . Ray Quote Link to comment Share on other sites More sharing options...
P Smith Posted May 4, 2011 Share Posted May 4, 2011 Hi Ray ive got mine from gwsthe have a number on the blade which isEP-5030Rx3 Looks like they are directly from GWShope this helps Paul Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted May 4, 2011 Share Posted May 4, 2011 One of our clubmembers has built one, and it looks tremendous! I believe it's Dave's first ever build of any description, and to say he's done an outstanding job really is an understatement. It flies as well as it looks too! tim Quote Link to comment Share on other sites More sharing options...
P Smith Posted May 4, 2011 Share Posted May 4, 2011 wow that is really good Quote Link to comment Share on other sites More sharing options...
Poul Børge Pedersen Posted January 26, 2012 Share Posted January 26, 2012 That last set of pictures looks great! I am building one , Have made the wing panels from 2 sheets of 3 mm eezeefloor sandwiched over a 150 mm drain pipe, dried for one week, used waterproof PVA glue. The body is 3/4 finished, also glued with PVA except for the vertical panels which were glued with polyurethane glue after brushing the contact surfaces with water to make it harden. Quote Link to comment Share on other sites More sharing options...
