Martin McIntosh Posted March 14, 2012 Share Posted March 14, 2012 Hi Mike, Received same board as yours today. Looks like it does indeed come ready for a quad. I googled `connecting KK board` and looked at `KK controller board for quad flyers` and although a bit Chinglese gives you the gist of it. I assume that all esc power connectors are commoned to the flight battery and that the board is powered via the servo outputs but have not had time (or courage) to connect it as yet. Martin Quote Link to comment Share on other sites More sharing options...
Mike Morcher Posted March 15, 2012 Share Posted March 15, 2012 Hi Martin Ok looks like my board is set up for KKQuadrocopter (+ Configuration) as its V2.3 if it was X Configuration it would be KKX and not KKQuadrocopter, but we will see when I power it up. Mike. Quote Link to comment Share on other sites More sharing options...
Mike Morcher Posted March 16, 2012 Share Posted March 16, 2012 Well Folks We are get there, just got to get 3 small cables for the receiver and then we shall see ? Mike. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted March 16, 2012 Share Posted March 16, 2012 Hi Kal...please can you take a moment to read this please....thanks Quote Link to comment Share on other sites More sharing options...
kal wise Posted March 19, 2012 Share Posted March 19, 2012 Posted by Steve Hargreaves - Moderator on 16/03/2012 12:54:36: Hi Kal...please can you take a moment to read this please....thanks Thanks Steve its very helpful Quote Link to comment Share on other sites More sharing options...
Mike Morcher Posted March 19, 2012 Share Posted March 19, 2012 Hi Laurent The build is going fine, now into the testing and flying ie hops next video flying Edited By Biggles' Elder Brother - Moderator on 08/04/2012 16:08:17 Quote Link to comment Share on other sites More sharing options...
Mike Morcher Posted April 8, 2012 Share Posted April 8, 2012 Hi All This is just an update video = Edited By Biggles' Elder Brother - Moderator on 08/04/2012 16:15:03 Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted April 8, 2012 Share Posted April 8, 2012 OK guys here your new all singing, all dancing combined quadracopter thread. I've done my pass to handle duplicated posts etc! BEB Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted April 8, 2012 Share Posted April 8, 2012 Hi all, well, my KK board came set up for a quad OK but on first tests in a warehouse a couple of motors died occasionally. This turned out to be the unused and untapped front mounts touching the motor windings, eventually destroying one of them. Having a ding dong with HobbyKing at the moment to get them replaced (Donkey motors, real donkeys). Will order rather better ones when they are back in stock so in the meantime must just wait . I hear that the gyros on the KK are not good enough to auto stabilize. What do you reckon? Quote Link to comment Share on other sites More sharing options...
Mike Morcher Posted April 8, 2012 Share Posted April 8, 2012 Hi Martin Shame about your motors,when you have the new ones fitted power up your Quadcopter and speed up but not to lift off or fly then hold it above your head and rock it about you will feel it stabilize, also you should have the pots set to 3/4 and then try lift off, you then adjust to suit you. Happy flying Mike Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted April 8, 2012 Share Posted April 8, 2012 Hi Mike, Before it died I managed a few short hops and experimented with the pots a little but probably had them set lower than that. The motors certainly responded to rocking but that was the point at which they started to fail. Will keep you posted, Martin Quote Link to comment Share on other sites More sharing options...
