Martyn Perks Posted March 30, 2011 Share Posted March 30, 2011 Can someone tell me... I have a Twin Star 2 lying idle at the moment which I would like to put back in the air. It used to fly on a Nicad 8.4v pack and now I have 3s Lipo packs instead. Can I reuse the speed controllers or will it all have to be binned? If so what setup would work best? Its got to be cheap as its only a spare plane ! Thanks Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted March 30, 2011 Share Posted March 30, 2011 Hi Martyn, You might be able to re-use the speed controllers if they can be configured for LiPos necessary higher cut-off voltage off around 3V per cell - 9V for a 3S. Don't run Lipos on a controller set for Nicads or the overdischarge will kill your battery! If you're using brushless motors the controller must be compatible - a brushed motor controller won't be useable. Speed controller f or brushless & Lipos Or - BRC do a complete set if you want to replace motors & esc. with a brushless setup BRC set Hope this helps. Cheers Edited By Richard Wood on 30/03/2011 20:05:24 Quote Link to comment Share on other sites More sharing options...
Martyn Perks Posted March 30, 2011 Author Share Posted March 30, 2011 Thanks Richard Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 30, 2011 Share Posted March 30, 2011 the motors wont last long on 3s. Quote Link to comment Share on other sites More sharing options...
Kelly Posted April 1, 2011 Share Posted April 1, 2011 My thread Twinstar brushless conversion. Not flown it yet Quote Link to comment Share on other sites More sharing options...
