whacky Posted April 5, 2011 Share Posted April 5, 2011 Hi all, Some years ago I bought a Raptor 30, work went mad and it went up to the loft never to be seen again until now. My question is what do I need to do to get it going/useable again? Steve Quote Link to comment Share on other sites More sharing options...
boggy Posted April 5, 2011 Share Posted April 5, 2011 hi Steve. firstly i would change all the fuel tubing(dont forget the clunk line inside the tank) Next i would pop off all the links one by one and try and ensure as best you can that non have become brittle.Probably fit a fresh rx battery. Ensure all the servo's are good and the gyro is working.(give the tail a swing and watch the tail yoke).Make sure the main blades are still good (if they are the TT woodies the can warp when stood for long periods) Before attempting to start the engine you may want to drop off the back plate and have a look at the rear bearing,check its not rusty.check the plug works .fresh fuel and good luck. Enjoy it its a great little helicopter to learn on Quote Link to comment Share on other sites More sharing options...
boggy Posted April 5, 2011 Share Posted April 5, 2011 if you need any parts. midland helicopters or revolution models are good sources Quote Link to comment Share on other sites More sharing options...
whacky Posted April 5, 2011 Author Share Posted April 5, 2011 Thanks boggy would there be a leccy conversion for it Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted April 5, 2011 Share Posted April 5, 2011 Hi whacky, still flying my original v1 raptor, chances are that minimal work is required. If its rusty, change it. Replace the battery (bit obvious) and a good dose of WD40 to the bearings (avoid getting anything on the clutch lining) check the linkages over and a good clean should see her as good as new. Not heard of any issues regarding the belt but worth checking the tension. The motor may well need freeing up, take out the plug and flush through with fuel till she loosens up, worth replacing the plug with new item if it looks a bit oiled up, also worth flushing the fuel tank and change the filter if fitted. Worth checking that the blades have not warped in storage, have heard of this with wooden blades in the past when strapped down to tightly for too long,no fix here, bin and replace. Finally worth checking pitch settings and general set up as storage can do strange things again if a link has been under load. hope that helps, Linds Quote Link to comment Share on other sites More sharing options...
boggy Posted April 5, 2011 Share Posted April 5, 2011 there is an electric version Whacky (TT550e) but if there is a conversion kit i dont know sorry. quick edit sorry tt raptor E550 Edited By boggy on 05/04/2011 20:06:08 Quote Link to comment Share on other sites More sharing options...
whacky Posted April 5, 2011 Author Share Posted April 5, 2011 No worries just my neighbour has a big field i can use behind our houses leccy would be quieter Quote Link to comment Share on other sites More sharing options...
