Tony Read Posted April 22, 2011 Share Posted April 22, 2011 I've been having a spot of bother putting my Beaufighter together. Its the way the tailplane fits into the fin. You heve to bend the fin one way and try to slot the tailplane in. Ok so here goes. Bend the fin, tailpane wont fit. Bend it a little bit more, still wont fit. Bend it ...snap! Doh! Still it fits now! Anyone else had this problem? Can't help thinking there must be a better way to mount the tailplane. I will be using brushed motors and gearboxes. Is there any advantage to using a single ESC as opposed to one for each motor ( have enough ESC's of suitable amps to do either option)? I was thinking of using 3 blade 8x4 props. GWS do counter rotating 8x4. Does this mean you have to buy a non-counter-rotating prop as well, or simply flip it round? Any input would be most appreciated. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 22, 2011 Share Posted April 22, 2011 If you use a single ESC then you will also need to decide how to wire the motors - series or parallel. Obviously, if series - and one dies - they all go out, but in parallel the current will be incrementally higher, possibly exceeding your ESC capability. Quote Link to comment Share on other sites More sharing options...
Tony Read Posted April 22, 2011 Author Share Posted April 22, 2011 Thanks Tim, had not thought of that. Reckon I will go with two ESC's. I assume that as they are brushed ESC's and motors I do not have to remove one of the wires to the receiver? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 22, 2011 Share Posted April 22, 2011 Well perceived wisdom is yes - you should. This is nothing to do with brushed versus brushless, but is to simply prevent each BEC unit on the ESCs from "fighting with each other".Power is then only fed to the rx and servos from the one BEC unit. Edited By Tim Mackey - Administrator on 22/04/2011 21:50:33 Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted April 26, 2011 Share Posted April 26, 2011 Thanks again Tim! I must admit that despite one or two niggles with the model its a fine looking plane and I'm looking forward to flying it soon. If I were to do another I would probably score a line on the fin to control the position of the crack which will occur when you bend it, and hide that crack below the tail decal. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 26, 2011 Share Posted April 26, 2011 Is it the ALFA beaufighter? ( ALPHA is a different thing )Nice looking, and generally nicely made and great flyers the Alfa stuff. Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted April 27, 2011 Share Posted April 27, 2011 Err yes it is. Can you change the name of this thread please to Alfa? Quote Link to comment Share on other sites More sharing options...
Tony Read 2 Posted April 28, 2011 Share Posted April 28, 2011 One thing, do I have to solder the 'supressors' onto the speed 300 motors if I am using 2.4 ghz radio? Quote Link to comment Share on other sites More sharing options...
Tony Read Posted May 27, 2011 Author Share Posted May 27, 2011 Got the motors and gearboxes installed and running but I don't seem to get much thrust. I am using speed 300 7.2v motors with 5:1 gearboxes driving 8x4 GWS 3 blade props (one counter-rotating). The lipo is a 2 cell 1600mah. This is, as far as I can see, is the setup that was used in the MW mag. It certainly is not trying to pull out of my hand when I throttle up. The props seem to be the right way round. Any ideas please? Quote Link to comment Share on other sites More sharing options...
Tony Read Posted May 27, 2011 Author Share Posted May 27, 2011 Just tried it with a 3 cell lipo. Plenty of power. Will I burn out the motors using a 3 cell though? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 27, 2011 Share Posted May 27, 2011 Fairly soon yes. Quote Link to comment Share on other sites More sharing options...
Tony Read Posted May 27, 2011 Author Share Posted May 27, 2011 So how did the Matt Boddington in MW get his to fly with the three blade props I wonder? On 2 cells I cant see it flying. Quote Link to comment Share on other sites More sharing options...
