Lord Depron Posted May 10, 2011 Share Posted May 10, 2011 Hi guys,thought I'd share my latest Depron project with you all.It's a semi scale TSR2,24 inch wingspan,length 38 inches.Powered by 2600kva outrunner with pusher prop.Control surfaces are taileron.Just needs a calm day now to maiden her,fingers crossed. Quote Link to comment Share on other sites More sharing options...
Rustymitch Posted September 10, 2011 Share Posted September 10, 2011 Looks good, how well did it fly? Have you seen the real one at RAF Cosford Museum, never realised how large they were. Quote Link to comment Share on other sites More sharing options...
Solid Snake Posted September 10, 2011 Share Posted September 10, 2011 Looks great good luck with the maiden Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted September 10, 2011 Share Posted September 10, 2011 Lets hope its more successful than the real one,is it semi scale because your motor fitted whereas the real one had to be modified for the motor to fit,and then it was recommended not to be used at full power. Quote Link to comment Share on other sites More sharing options...
Lord Depron Posted September 12, 2011 Author Share Posted September 12, 2011 Thanks for the comments guys,she flys extremely well and has a fair turn of speed.At low speed she takes on that characteristic nose high attitude with no sign of dropping a wing tip,she also glides very well. Quote Link to comment Share on other sites More sharing options...
kevin wild Posted September 13, 2011 Share Posted September 13, 2011 looks greatdo you have any construction photos ?good luck with the test flightKev Quote Link to comment Share on other sites More sharing options...
