Tim Cheal Posted May 14, 2011 Share Posted May 14, 2011 I have an Acro Wot with a single aileron servo. I am considering adding a second aileron servo. This would give increased redundancy in case of a servonfailure, and flaps or reflex. I have read mixed advice about which would work best or even whether either is worthwhile. I fly from a field which is 75m square and in light winds it can sometimes be tricky to get it down over the trees.Does anybody use flap(erons?) or reflex with an Acro Wot, and would you be able to let me know if it makes much difference to overall landing distance?Many thanks.Tim Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted May 14, 2011 Share Posted May 14, 2011 I would not recomend useing the ailerons as flaps on a tapered wing, this would give wash-in, and lead to tip stall, the acro wot has a generously thick wing, it slows up enough, 2 servos is always a good idea, but we where flying these 30 years ago, with just one central servo try crabbing the model, using aileron and opposite rudder, this is a speed bleeder,and is quite controllable, Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 15, 2011 Share Posted May 15, 2011 Absolutely agree with Alan on that. Quote Link to comment Share on other sites More sharing options...
r6dan Posted May 15, 2011 Share Posted May 15, 2011 As Alan says by crabbing my Acro Wot it almost comes in at less than walking pace, flaps are just not needed. Quote Link to comment Share on other sites More sharing options...
Tim Cheal Posted May 15, 2011 Author Share Posted May 15, 2011 Thanks guys. I'll hope the wind drops so that I can go flying!Tim Quote Link to comment Share on other sites More sharing options...
