iawnski Posted May 21, 2011 Share Posted May 21, 2011 hi as i was useing my futaba ff9 tx this morning i went to put up elevator trim on the tx and it would not do anything ,it will give me down trim but not up,it is digital trims on ff9 ,any one got any idea whats going on here ,should i send it back to futaba ? any help here please Quote Link to comment Share on other sites More sharing options...
simon barr Posted May 21, 2011 Share Posted May 21, 2011 Silly question really, but you didn't already have full up trim in, did you... If not, then it needs checking out. Quote Link to comment Share on other sites More sharing options...
iawnski Posted May 21, 2011 Author Share Posted May 21, 2011 hi simon ,no it was in the middle and i went to put some up trim in and nothing happened the line on the display works ok for down but it wont come back now to neutral on the dial its stuck,the servos work ok in down trim but domnt move for up trim hope this explains itself Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted May 21, 2011 Share Posted May 21, 2011 hello iawnski--did you get your front cover replaced like you were planning?...when i did mine - a couple of times i had to reseat the digi trim switches...if they wern't sitting spot on-they wouldn't work properly... ken anderson ne..1. (tech dept/not)Edited By ken anderson. on 21/05/2011 13:10:08 Quote Link to comment Share on other sites More sharing options...
iawnski Posted May 21, 2011 Author Share Posted May 21, 2011 hi ken no didnt do it in the end chickened out i havent touched the tx so am at a puzzle here hopeing one of the tec guys on here will come along iawnski Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 21, 2011 Share Posted May 21, 2011 It sounds like the lever is simply not actually depressing the button - you need to get the case off and have a looksee. Quote Link to comment Share on other sites More sharing options...
iawnski Posted May 21, 2011 Author Share Posted May 21, 2011 ok timbo will have a scan tonite hopefully, let u all no how ui get on ,off shopping now Quote Link to comment Share on other sites More sharing options...
iawnski Posted May 21, 2011 Author Share Posted May 21, 2011 yo boys while waiting for her indoors to do the make up thing i had a scan at the tx and guess what the little thing that makes the trim goes up and down is a bit faulty in the pcb,anyone no were i can get one from looks like just 2 soldered joints in back of pcb, thanks guys im a happy chappy now we have got to the heart of the prob right shopping here come war paint on lladudno here i come Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 21, 2011 Share Posted May 21, 2011 Its probably a little microswitch soldered directly into the PCB - without seeing it, I couldnt say, but I likely have something here that will do the job. Maybe justthe solder joint itself needs re-doing. Quote Link to comment Share on other sites More sharing options...
iawnski Posted May 22, 2011 Author Share Posted May 22, 2011 tim i think ur right mate ,i have just desoldered them and resoldered them ,they seem ok at the moment moveing as they should ,if i have any more probs will get in touch m8 thanks guys for all the help Quote Link to comment Share on other sites More sharing options...
